Old 09-11-2016, 08:25 PM   #1
Norm excella's Avatar
1971 31' Excella 500
Many , Louisiana
Black water tank check
Which would be the more practical or easy way to check my back tank for a leak. It is leaking into belly pan after about 10 gallons of water flushed into it. Do I need to peel the shell underneath or go through the inside floor? 1971 Excella 500. Where exactly would my tank be located?
Norm excella is offline   Reply With Quote
Old 09-11-2016, 08:48 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Are you sure it is a 71. As far as I can tell Excellas were introduced in 1980. Could you have a Sovereign?
Old 09-11-2016, 09:10 PM   #3
1979 23' Safari
Wayland , New York
Rear bath with the short toilet mounted up on a little platform?
The tank is under the platform but above the floor. Its capacity is about 8 gallons I think. May be why it's leaking. It's full and leaking out at the toilet flange. You have to remove the sink countertop, toilet, and cabinet on top of the platform to get to the tank. First I'd dump the tank, then get a new seal. Remove the toilet, replace the seal and it may fix the leak.
If the toilet sits flush on the floor the tank is below it under the floor. There is a big galvanized pan under the trailer holding it up. The pan is bolted up. Remove the bolts and pan to get to the tank from below. Still may want to remove the toilet to check from the top first before pulling the pan from below.
Old 09-12-2016, 03:39 AM   #4
Many , Louisiana
Thanks Joe
Old 09-12-2016, 07:07 PM   #5
1979 23' Safari
Wayland , New York
Norm!
Is the toilet on the platform or the floor? Just curious? Some had them on a platform more centerline. Some on the floor but more in the corner.
Joe
Old 09-13-2016, 01:10 AM   #6
Many , Louisiana
It's flush on the floor in the corner. Thanks again.
Old 09-27-2016, 01:01 PM   #7
Many , Louisiana
Without a doubt an Excella!
Black tank check valve bsedor Sprinter and B-van Forum 18 07-12-2016 02:17 PM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 06:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-02-2011 12:51 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
