Old 12-28-2003, 05:10 PM   #1
David Hall's Avatar
Black Water Tank
I have a 1961 26' overlander and want to know the size of the black water tank if anyone would be so kind to let me know, also the gray water drains come out below and into the Black Tank drain pipe, am I missing something or does the gray water just drain to the ground. What does one do when he has no gray water tank at a camp with no hook ups? Need answers....Thanks...Dave.....
Dave
David Hall is offline   Reply With Quote
Old 12-28-2003, 06:16 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
David,
I do not know the size on your black tank. The gray water in your vintage does not have a tank and just drains out just before the cap. If you are camping without hookups there are two options depending on the campground or state rules. You can either connect an old green water hose, approx 5-9 feet and allow it to drain on the ground under the trailer. The second is to buy a blue belly portable tank and hook up to it. You can either tow it with your truck or if it is small enough drag it by hand to to a dump location.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-28-2003, 06:22 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Black Water Tank
Greetings Dave!
I am fairly certain that your Overlander has an eight to nine gallon black water tank - - one of my friends has a '60 Overlander and I have a '64 Overlander and both of our Overlanders have black tanks that are slightly more than 8 gallons but less than 9.
Unless I am mistaken, your '61 Overlander still has the black tank that is mounted on top of the floor (the toilet is on a raised platform above the tank creating a step-up to the toilet). If this is the case, your only option with the gray water is a blue porta tank for gray water (these are available at most camping supply outlets in a variety of sizes - - I have a 10 gallon and a 20 gallon and find the 10 gallon to be a bit more practical). If the black tank on your Overlander is mounted below the floor as is the case with my '64 Overlander, you have the option of "backing-up" the gray water into the black water tank. This is done by placing a solid terminator valve cap on the dump tube and then opening the dump valve on the black tank - - the gray water then will flow into the black tank (downside is that the black tank will fill VERY quickly and dumping becomes a bit messy as the dump valve must be closed prior to dumping and the area between the dump valve and terminator cap will be filled with sewage that will spill out when the terminator cap is removed - - you will need a small bucket to catch the trapped sewage when dumping).
If your Overlander has the above floor black tank, you do have the option of adding a gray water tank below the floor. It would be somewhat more costly than using a blue tank, but would be a more permanent solution. I haven't investigated this as my black tank is under the floor which severely limits the viability of adding a gray water tank.
Kevin
Kevin D. Allen
AIR #827
Old 12-28-2003, 07:24 PM   #4
David Hall's Avatar
Thank you very much for the info, this is my first RV and I'm lost as to what it's all about but hope to learn with your help..Thanks...Dave....
Dave
