Old 03-19-2009, 09:33 PM   #1
1965 22' Safari
California , Kentucky
Black water tank
Do not know how to use this thread effect? I have a 1965 safari and need to replace the styrofoam under the b water tank. I have removed all of the bathroom and have the new floor ready to install. What about expanding foam? The old styrofoam is history.How do I get back to this thread?
RiverRat is offline   Reply With Quote
Old 03-19-2009, 09:49 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have heard expanding foam will deteriorate from the vibration of road travel.
Old 03-19-2009, 10:06 PM   #3
1965 22' Safari
What is an alternative?
Old 03-20-2009, 01:19 AM   #4
Strofoam is available almost any place.
It offers support as well as insulation.
If you use expanding foam, in short order, you will use some bad words that you have never used before, guaranteed.
Old 03-21-2009, 08:38 AM   #5
1965 22' Safari
How do I form the styrofoam to the convex black tank?
Old 03-21-2009, 09:05 AM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Any type of grinder or saw will make quick work of styrofoam even a sander, but that will make a big mess... Wear a mask and you could have someone with a shop Vac standing next to you to catch most of the styrofoam..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 03-21-2009, 09:51 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Another option if you have access to the hardware in a rheostat attached to a wire loop. Turn up the juice so the wire gets hot enough and it cuts through styrofoam like cheese. Makes a little nasty smoke but you won't be cleaning up styrofoam dust for the next year.
There is also a specialized file / rasp that works OK on styrofoam called a Sure Form
Old 03-21-2009, 06:56 PM   #8
1965 22' Safari
I guess I will pull the old styro ( They call it starfoam round here)out of the trash and try to make the same shape with a grinder.I'd probably fry myself with the electric alternative. Thank you all...........(Y'all)
Black Water Tank robertpeters Waste Systems, Tanks & Totes 13 06-13-2007 06:26 PM
need new black water tank KHarris Waste Systems, Tanks & Totes 4 09-24-2006 08:34 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
