Old 11-16-2015, 04:46 PM   #1
1973 31' Sovereign
Montalba , Texas
Black water tank
I have a 1973 sovereign 31' side bath need to know how to get black water tank out it has a leak can anyone help thanks
mkcox is offline   Reply With Quote
Old 11-16-2015, 05:32 PM   #2
Gainesville , Florida
I think you have to remove the belly pan to start. Straps hold it up?? after pan removed.
Old 11-16-2015, 07:57 PM   #3
1973 31' Sovereign
Montalba , Texas
Tank set on top of floor not sure if I need to take bathroom wall out to get tank out
Old 11-17-2015, 06:19 AM   #4
My comment then was incorrect. Will be interesting what everyone else has to say.
Old 11-18-2015, 07:55 PM   #5
1973 31' Sovereign
Sumiton , Alabama
Black Tank Removal
black tank replacement. Did you find out how to remove your black tank? I have the same model and in the process of removing my black tank as it is broken also.. How does it come out of the dump value? Did you buy a new black if so we're did you get it?
mingle51 is offline   Reply With Quote
Old 11-18-2015, 08:50 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy and believe you have a similar BW tank.
I did not have to remove the inner skin. The toilet must be removed along with any cabinetry above the tank. Mine has a hose clamp on the outlet of the tank which must be released. Remove the box surrounding the tank and it will lift up and slide out of the sewer connection.
Post a pic of your setup. It will help.
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 06:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-02-2011 12:51 AM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 07:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-30-2005 12:03 AM
