06-10-2008, 08:18 PM
2001 19' Bambi
Ashland
, Oregon
Black water sewage hose
We need a new waste hose. Of course, there are many choices; four types of hose and several different lengths. We have a 19 ft. Bambi. Do we need the ultimate, nuclear-attack proof hose? If so, fine. What about length? Ten feet? Fifteen? Twenty? Any suggestions?
06-10-2008, 08:22 PM
More than one rivet loose
Los Alamos
, New Mexico
I have two "standard" hoses from Wal-mart total length 40 feet. I have used all for a couple of times. My high use hose is a little heavier than the extension.
Michelle TAC MT-0
Sarah, Snowball
06-10-2008, 08:52 PM
Airstream - Other
Bosque Farms
, New Mexico
Just don't buy the transparent kind. It's gross.
Lynn
ACI Big Red Number 21043
06-10-2008, 09:17 PM
1994 34' Excella
1978 31' Sovereign
Mansfield
, Georgia
Hey Muddy Waters,
I carry two "stinkie slinky" type of hoses, with a mating coupler so I can join the two together. One hose is 20ft. long, the other hose is 30 ft. long.
The operating theory is that you use the shortist black water hose possible to accomplish the mission.
If you arrive at a camp site that requires a long sewer run, you can join the two hoses together to meet your needs.
The same operating theory is valid for "white" potable water hoses. If you carry two hoses of different lenghts (15 ft and 25 ft hoses), use the shortest when possible. Or if necessary, join the two together to reach the fresh water supply.
I also carry a green 25 ft. non-potable hose, with a one way valve connector, to flush out the stinky slinky hose. Just do not store the white and green hoses together.
06-10-2008, 09:51 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use a Sewer Solution, and carry 4 10' sections. We usually only use one. We also carry 10' of "slinky" hose for use at public dumps where the Sewer Solution can not be used.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-10-2008, 09:53 PM
1966 24' Tradewind
Placerville
I love our Sewer Solution ....except when a grandson drops a Baby Wipes down the toilet.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
06-10-2008, 10:44 PM
2006 19' Safari SE
Tucson
We take 2 "slinkies" on our trips...I think both are 10 or 12 feet long...and couple them when we need extra length. We rarely need them both, but better to have the length just in case. Slinkies do spring leaks if dragged across pavement, etc., so be careful with that and buy the heavier ones i fyou can...they will last longer and are worth the little extra cost. If you are outfitting your rig for sewer needs, we highly recommend some kind of hose support system for the hose so you can direct the hose and create a "downhill" flow toward the sewer dump hole. Here's the one we like best, available at Campingworld and other RV outfitters. It's compact and works great...far better than rigging a downhill flow using rocks and boards and whatever else you can find. Remember...it doesn't run uphill! Flexible Sewer Hose Support - Camping World
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
06-11-2008, 10:04 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
And don't forget the most important part: Airstreams usually come with Thetford fittings. Most hoses you find are equipped with Valterra fittings, which are a little (just enough!) smaller.
Pat
06-11-2008, 10:30 AM
2001 19' Bambi
Ashland
, Oregon
INVALUABLE advice on here. Keep it coming. Who knew buying a sewer hose had so many aspects to it?!
06-11-2008, 10:46 AM
1964 24' Tradewind
Portage
, Michigan
I carry three sewer hoses, two are 10 or 15 feet when stretched out, the other is 5 feet used mostly for emptying the blue tote.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
06-11-2008, 01:50 PM
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
KEITHC pretty much nails it for us. So far so good with the extra slinky, coupler and extra length of white fresh water hose.
Another tip (a NO NO to some) would be to carry a grey hose and attaching hardware for evacuating the "Wash Water" onto the ground when practical and no sewer is available.
HAPPY TRAILS
In dog years, I'm dead!
06-11-2008, 02:38 PM
1975 31' Sovereign
Searcy
, Arkansas
Rhino Flex
I started using this hose about a year ago and love it. It compresses to 45" and expands to 15'...I tis very tough and flexible...it bends and holds its shape where ever you put it and will not slinky back.
You do have to modify it a little for it to fit into the sewer hose holder under the Airstream.
Just my opinion!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
06-11-2008, 04:14 PM
Los Alamos
, New Mexico
Pat
My 06 classic has Valterra. I think 06 and on all have Valterra.
Michelle TAC MT-0
Sarah, Snowball
06-11-2008, 04:35 PM
Some Place with a German Name
My 04 Bambi had a Valterra.
06-11-2008, 07:22 PM
2001 19' Bambi
Ashland
, Oregon
It is impossible to find Thetco products, at least on Google. Will have to check and see if the Valterra fits our 2002 Bambi.
What about 'Blue Line'? Will those fit, does anyone think?
06-11-2008, 08:22 PM
Airstream - Other
Bosque Farms
, New Mexico
The most frustrating part about hoses, at least for newbies, is to understand how to get their various fittings to fit together. There is a painless way to do it, though it's a little hard to explain in on the net. And, drat, you're way too far away to drop by here for a training session (on this and related matters) ...
Oh, by the way, some states now require you to have a sealed connection between the end of your hose and the sewer itself. Either you can purchase a cheap "donut" to seal it, or you can get one of the more expensive plastic 90-degree fittings. Both kinds are generally available at Walmart. (We used to use the donuts on our rig until somebody accidently left behind one of the expensive doo-dads here at the park ...)
Lynn
06-11-2008, 08:25 PM
Retired.
, At Large
Umm, that is "Thetford", probably why you've had no luck.
As for slinkies, there are generally three grades, standard duty (will tear pretty quick), medium duty (will tear, not as fast), and heavy duty (will eventually tear). We have 3 lengths of slinky hose that totals about 30 feet, and have never used one of the 10 foot lengths.
06-12-2008, 12:41 AM
1978 28' Ambassador
Morada
Many RV dealers sell a Thetford to Valterra 'adapter' that fits on earlier AS's with the larger Thetford sewer hose outlet. You can just twist this adapter on your AS and use all the current fittings, etc.
Universal Valve Adapter - Camping World
Ray & Pat; Morada, CA
06-12-2008, 09:55 AM
2001 19' Bambi
Ashland
, Oregon
Thanks again for some useful information. I did figure out that it wasn't 'Thetco' but 'Thetford' and that made it somewhat easier to find them online. I ordered two ten-foot hoses. Now I need to figure out if there is a special connector required to hook them together.
Man, this sewage thing is taking a lot of energy to unravel!
06-12-2008, 10:01 AM
Ready-to-Travel
Walkerton
, Virginia
Muddy, I fear I may have steered you wrong (I though all AS's were Thetford). Did you verify before you ordered?
Pat
