Old 09-22-2013, 01:21 PM   #1
2005 19' International CCD
Belmont , California
Black water flush leaks
Well I did a black water dump and then hooked up a garden hose to the black water flush hose bib, turned it on and all I heard was water spraying and it was all draining onto the ground. I do not think any water went into the black water tank. I looked inside under the bathroom sink and I see what looks like an anti siphon valve but nothing on it to open/close. There was also a little bit of spray in there. I assume it leaked inside because of all the pressure backed up from nothing going into the black tank. Am I missing something in this process? The manual mentions the vacuum break and check valve. I assume that is what I think is the anti siphon valve? Could this valve be messed up? Does not look easy to take apart. Connections look like some sort of pressed on clamps.
djpierce is offline   Reply With Quote
Old 09-22-2013, 03:02 PM   #2
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
Had a similar problem with the valve that I believe you are referencing. See the photos in the thread mentioned below. It's was relatively easy fix as ours
had threaded connections. It was a bit hard to reach. I think I've used it like once since it's been fixed since there are other easier alternatives as are mentioned in the thread.
http://www.airforums.com/forums/f44/...ire-70481.html
Good luck.
Hansom-Man is offline   Reply With Quote
