Old 07-23-2013, 03:09 PM   #57
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Since I don't know about the 19' plumbing, I can only say to check the fittings under the sink for a leak—run water into the sink and see if you can find a leak. Fill the sink part way and then let it all drain at once. The P-trap under the sink or one of the pipes attached to it may have a loose fitting that needs to be tightened. It can be done by hand. Ours started to leak after a few years.
A drain system is not designed for high pressure, so a loose connection that gets a sink full of water at once can leak if not tight enough. A full tank could back up and put pressure on a fitting, but it usually shows up in the shower first since it is the lowest point in the system. I assume a 19' has a shower. If you have one tank (grey and black together) you don't want to see the results of a backed up drain system.
I don't know if this helps, but loose fittings are not uncommon in sink drains—either not tightened sufficiently at the factory or loosened by travel. It happens at home too because sink drains like to loosen over time too. A loose fitting is the simplest thing to check.
Gene
Gene
Black Water Flush Blocked ElliotA Plumbing - Systems & Fixtures 6 04-01-2017 06:26 PM
My toilet won't flush on city water godaddy64 Plumbing - Systems & Fixtures 12 09-18-2011 02:37 PM
Black water flush system mjayjensen Waste Systems, Tanks & Totes 4 07-10-2011 05:21 PM
Black water flush woodssd Waste Systems, Tanks & Totes 3 06-08-2011 12:19 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
