Old 06-08-2011, 12:13 PM   #1
2008 23' Safari SE
mt pleasant , South Carolina
Black water flush
The first couple of years we had our 23' Safari when you hooked up the black water flush you can hear the ponding of the water jets, now its silent. Any ideas on whats wrong or suggestions? Thanks
woodssd is offline   Reply With Quote
Old 06-08-2011, 12:25 PM   #2
Air Apparent's Avatar
Northern Illinois , Illinois
At Alumapalozza, Tim from Airstream Corporation stated that the backflush is a use it or lose it item. That if not used consistently it will become clogged and there is nothing that can be done to get it working again.
Hope this helps.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 06-08-2011, 12:41 PM   #3
2008 23' Safari SE
Thanks. We use it everytime we camp with the exception of about 4 months out of the year.
Old 06-08-2011, 01:19 PM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
give it a try
woodssd
You may not get it back without dropping the tank but you should still try. Fill it with water and pour some bleach in there when you’re not using it (down the toilet). Let it sit for a few days and drain the tank. Try the flush and if it does not work then fill again. Let sit for a few more days. If it still does not work, leave the black water drain open and hook up the hose to the flush. Let sit for a while. In this mode I would not want to leave unattended as the clog may not let go and you would not want to come back to find a busted hose, on the inside, has soaked your unit.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 09:27 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 11:37 AM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 10:52 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 11:15 PM
Unable to dump black water tank before 20 deg. forecast mikeandnora Waste Systems, Tanks & Totes 3 02-04-2011 10:46 AM
