Old 08-22-2015, 08:00 AM   #15
1981 31' Excella II
New Market , Alabama
Somewhere I have a stick with a hole in the end coming out at 90 degrees that fits on a garden hose. If you were to stick that in the exit and flush the valve area with water with the valve open, it should dislodge anything stuck in the valve. My valve would not shut off because the seal got caught by the blade. This was probably a result of something stuck in the valve that pushed the lip of the seal the wrong way and the blade held it that way. I would leave the valve open so the seal does not take a set. Here is a photo of my valve.
Here is the thread on my valve replacement issues as well.
http://www.airforums.com/forums/f444...th-109487.html
Black water dump valve push pull rod missing 79excella500 Waste Systems, Tanks & Totes 2 08-26-2009 08:44 PM
Black Water Dump Valve SJ Brown Waste Systems, Tanks & Totes 2 06-17-2009 07:24 PM
Black water Dump valve Cautions r.baker43 LP Gas, Piping, Tanks & Regulators 4 01-23-2006 07:25 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 01:17 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 08:22 PM
