Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Prev Previous Post   Next Post Next
Old 08-26-2009, 05:51 AM   #1
Profile:  1979 31' Excella 500
Odenville , Alabama
Black water dump valve push pull rod missing
Hello, I have just purchased a 79 Excella 500 center bath. When the gray water tank had some water run into it which will not close all the way, I noticed water dripping out of the hole where the rod is supposed to go that leads to the dump valve under the belly. Does this rod screw in or is it replacement valve time? Please Advise!
79excella500 is offline   Reply With Quote
black water tank, dump valve
Black Water Dump Valve SJ Brown Waste Systems, Tanks & Totes 2 06-17-2009 08:24 PM
Black water Dump valve Cautions r.baker43 LP Gas, Piping, Tanks & Regulators 4 01-23-2006 08:25 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 02:17 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 09:21 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 09:22 PM
