Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-17-2009, 05:19 PM   #1
Profile:  Currently Looking...
Mount Vernon , Washington
Black Water Dump Valve
I have an 87 Argosy 27' trailer and the black water dump valve is stuck closed. I am unable to open it via the handle. Oh by the way it is full.
Any ideas and how to remedy the situation would be much appreciated.
SJ Brown is offline   Reply With Quote
Old 06-17-2009, 06:50 PM   #2
3 Dog Nite's Avatar
Profile:  1974 25' Tradewind
Cleveland , Tennessee
I see 2 options. 1) Wiggle & tug & push gently on handle till it lets go. Be sure to be hooked up for dumping if it frees up. 2) Get somewhere you can dump freely on ground or be able to clean up afterwards. Put on some old clothes, facemask, & a snorkel and start undoing the 4 bolts that hold the valve in place. Good luck in the endeaver of your choice. i hope option 1 works out for you. I had to do option 2, but my tanks were clean.
Ricky
I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749
1974 25' Tradewind - no TV yet
1989 345 LE Classic Motorhome
Courtesy Parking; 20 amp, water, dump, wifi
'tween exits 27 & 33, I-75
3 Dog Nite is offline   Reply With Quote
Old 06-17-2009, 08:24 PM   #3
bibbs's Avatar
Profile:  Webster , New York
I had the same problem,used a LOT of force,and it opened. Since yours is full,I would figure out a way to pump it out,before I took the valve apart. Yuck
Bibbs
bibbs is offline   Reply With Quote
Busted the black plastic handle off one of my dump valve gates wacnstac Waste Systems, Tanks & Totes 7 08-07-2006 10:23 AM
Black water Dump valve Cautions r.baker43 LP Gas, Piping, Tanks & Regulators 4 01-23-2006 08:25 PM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 02:17 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 09:21 PM
black-water dump valve... Chuck Waste Systems, Tanks & Totes 11 09-01-2002 09:22 PM
