Old 02-28-2013, 05:57 PM   #1
2000 25' Safari
Hansville , Washington
Black water drain valve handle broken
I broke the handle off of the black water tank drain valve. There are not enough threads left on the valve rod to screw the handle back on. Is there a fix for this? I hope I don't have to replace the valve. AS is a 25' 2000 Safari.
I did fix the leaking range vent by replacing it with a new unit and sealing iton with a putty type tape from the local RV supply. Thanks to all who responded to that thread.
jandmderoy is offline   Reply With Quote
Old 02-28-2013, 06:13 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I just re-threaded the rod when that happened to me. The rod is very soft steel and easy to thread.
Hope this helps
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Black and Gray water holding tank leak GoodRed Road 1974 - 1979 Ambassador 0 09-19-2011 04:39 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Broken Thetford Valve Handle casa3805 Waste Systems, Tanks & Totes 4 04-23-2011 06:20 PM
