Old 01-13-2016, 01:31 PM   #1
2016 28' Flying Cloud
The Plains , Ohio
black water drain too low
First time out in my new FC28. I connected the sewer hose to the dump receptacle which was slightly uphill from my trailer. So I went and got one of those accordion type sewer hose supports and I find the support is higher than the drain. Does anyone use one of these support systems with an AS?
Richard
whitegs is offline   Reply With Quote
Old 01-13-2016, 03:56 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
One came with my trailer. Only used it a couple of times when the ground pipe was too high. Seems to work as advertised.
MICHAEL
Old 01-13-2016, 04:33 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I have one but rarely used unless it's an extended stay.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-13-2016, 04:52 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I don't use mine
CRH is offline   Reply With Quote
Old 01-13-2016, 05:48 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It should be possible to remove the segments that are too tall, and just use the shorter segments.
I don't use one personally since my Airstream Interstate has a macerator pump instead of a slinky. But I have seen them in use, and being a (former) engineer I can't help but try to think of a fix.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-13-2016, 05:55 PM   #6
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
If I understand your question correctly... In this situation I just bend the taller supports out the way and rest the hose on the first stance that is the correct height..
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-13-2016, 05:58 PM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Or really stretch it out so it's very long and low
2012 Dodge Durango Hemi/AWD
Old 01-13-2016, 06:46 PM   #8
billiards's Avatar
rochester , Minnesota
not a real answer to problem...however we just found that our winter campsite in Tucson requires support OFF THE GROUND they claim it is city law..
billiards is offline   Reply With Quote
Old 01-14-2016, 08:25 AM   #9
AWCHIEF's Avatar
Images: 33
I have heard of that requirement in some locals, have yet to experience it.
This is similar to what I have,
MICHAEL
Old 01-14-2016, 08:54 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Good picture. Makes me think of the Winter Olympics and the bobsled run.
There ARE a lot of campgrounds where the sewer inlet is 3 feet from the trailer and only one inch down, and if you use a slinky you can't compress it enough to make it a straight shot to the drain. I also note that newer campgrounds seem to have raised the sewer outlets... Probably some health regulation? One of the worst I've seen is Jackson Center's Terraport. When I back up my mid-bath 25 FB the outlet on the trailer is actually LOWER than the inlet in the ground - and it's about 22 feet away. I use the Sewer Solution so I can get the tanks pretty well emptied even so, but I've seen more than one other camper doing the "lift the boa constrictor" technique to milk their slinkies.
Dunno what I'll do with my SS if I run into a campground where it has to be off the ground. I suppose I'll just leave it in the bucket until the gray tank needs to be emptied, then use it and put it away. Or maybe I'll just wrap all the excess around the bucket securing it with duct tape, and use the bucket as a central support. "Oh the pooh goes round and round, whoa-whoa and it comes out here..."
Foiled Again is online now   Reply With Quote
Old 01-14-2016, 09:21 AM   #11
Johnco's Avatar
2006 19' Safari
Anaheim , California
I go cheap old-school, I carry a couple of short lengths of plastic rain gutter in the bumper. Hose fits perfectly and the height can be adjusted with rocks, twigs, firewood, anything handy.
Johnco is offline   Reply With Quote
Old 01-14-2016, 10:51 AM   #12
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Sewer Solution will solve the problem as it will force sewage slightly uphill.
TinCan
graysailor is offline   Reply With Quote
Old 01-14-2016, 11:58 AM   #13
Mrjkq's Avatar
Venice , Florida
A few years back I purchased a Sani-Con Tank Buddy. Its a portable macerator pump that fits with a bayonet lock on the RV outlet. To operate, it needs 12v power so I attach the alligator clips on the macerator to my portable battery jump box and it easily pumps up hill through the included 20ft one inch hose. The Tank Buddy comes in a small tool box for convience & keep it in the bed of my truck along with the battery jump box. Since I've had my AS I haven't used it but keep it with me for situations like up hill pumping.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 01-14-2016, 12:42 PM   #14
2010 22' Sport
Boise , Idaho
We rarely use ours and when we do, it's just the shorter portion of the set up. The RV park in Sedona requires them. We've been in RV parks in Tucson twice and I honestly don't remember if we used it our not
baldwin6601 is offline   Reply With Quote
Hitch Ball Too High, or Too Low SteveH Hitches, Couplers & Balls 30 10-21-2014 05:10 PM
How low is too low? Mrs. Bale Electrical - Systems, Generators, Batteries & Solar 6 08-16-2011 07:19 PM
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 59 12-18-2009 02:56 PM
Water Heater Adjustment? Gas Pressure too low? chasrahm Water Heaters, Filters & Pumps 1 08-10-2009 10:27 AM
Drain valve too low wayner1239 Waste Systems, Tanks & Totes 3 02-18-2003 11:45 AM
