Old 07-03-2004, 11:22 AM   #1
1975 24' Argosy 24
Burlington , Ontario
Angry Black-Water Caution
undefinedundefinedundefined
WARNING WARNING.
iF YOU HAVE TO WORK AROUND THE bLACK wATER DISCHARGE AREA
make sure that you flush the tank out and refill it with a bleach solution.
Use gloves and appropriate body cover,plus a full face mask.
I flushed mine and was working under the unit removing the valves and pipes and a bit of dripping fell on my forehead.
A few days later I became very ill. and on my forehead and the eye brows scabs and pimples appeared. the doctors said I had Shingles, and said all would be well. I was medicated. IT DID NOT GO AWAY. later they said it was something else, but did not know what.
I was ill all summer. Finally it calmed down and I was applying Lamasil. It helped, but to this day I get flair ups and irritation.
FORE WARNED SHOULD BE ENOUGH.
Best of luck
Rae Burlington,Ont.
raebaker06 is offline   Reply With Quote
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
