Old 08-09-2016, 03:57 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Black Water Blues
Been having a steadily increasing black water leak. Started off just near the discharge pipe, but now will leak out of the belly pan across the whole rear. Took off the banana wrap today. There is no way the leak can be coming out of the valve and leak across the whole back belly pan as the frame is in the way. If I fill the black tank all liquid leaks out without pulling the dump valve. Maybe a gasket between black tank and valve? Maybe a cracked black tank? Ideas/ suggestions?
PS Valve photo is upside down. I will repost.
Name:	Tradewind Dump Valve.jpg
Old 08-09-2016, 04:12 PM   #2
Lumatic's Avatar
1993 34' Excella
Images: 16
3 timesis the charm, I hope. Photo keeps ending upside down. So stand on your head if this still is not right.
The valve is a Thetford, Since it has to come out anyway, I will replace with a new Valterra. Also no grey tank in this baby.
Old 08-09-2016, 07:32 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Now that you have a bit of visibility with the banana wrap off, fill your black tank with fresh water and grab your flashlight. Maybe you can see where it might be dripping.
I think your trailer has an above floor black tank. I suspect it may be cracked. Replacing it will be a big project.
David
Old 08-09-2016, 07:47 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It looks to me like the piece of plastic pipe (the tee with the flange) just below the valve is separated from the valve. It looks like the fasteners are loose. Not sure it that is contributing to the problem, but I would not be surprised.
Also check the tightness of the clamp bands on the rubber coupling. There is pressure there when you open the valve.
Alan
Old 08-09-2016, 07:58 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
It is an above the floor tank.
The valve body does not appear to be leaking.
Now that I blew off all the muck I will fill the tank tomorrow and see if I can get a better idea where the leak is.
There is also an about 1/2" ID line next to the valve. Anyone have a guess what it is for.
One positive, very little rot in the subfloor, only surface rust on the frame, outrigger and rear plate, for a 71.
Old 08-09-2016, 08:21 PM   #6
sealaker's Avatar
1993 30' Excella
Winter Park , Florida
I had the same thing....leaks coming from the belly pan ... convinced it was a black tank crack. After having to special order a black tank from Jackson Center and shipped down to Florida...I found out it was my Thetford valves...Both... Black and Grey Tank Valves. Airstream was kind enough to take the tank back, but did have to replace the valves and brackets. I did go back with Thetford Valves. All fixed and belly pan back up. Looked as if the previous owner had let it go through the winter without draining as both valves were cracked. Big project, but learned a lot.
sealaker is offline   Reply With Quote
Old 08-10-2016, 06:40 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I believe that 1 1/2 inch drain pipe below your dump valve is the gray water drain. The 71s did not have a gray water tank. You can hook a slinky to your drain port and drain gray water to the sewer hook up, or you can drain it to a portable waste water tank and wheel it to a dump station. But folks no longer drain gray water on the ground.
Fill your above floor black tank and see what happens.
Good news on your subfloor and frame inspection. Many of these vintage trailers suffer from moisture damage in the form of rot and rust. Mine did.
David
Old 08-10-2016, 08:20 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Like a lot of things, depends.
Old 08-10-2016, 08:35 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
I have tried at least 6 times to attach the photo right side up. No matter what I do, including retaking the photo it is upside down. The photo was taken right side up.
Old 08-10-2016, 10:18 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you tried rotating your phone or camera? Then take the photo.
Old 08-10-2016, 11:31 PM   #11
CRH
1995 25' Excella
xxxxx , xxxxxx
I bet the adapter between the valve and tank has cracked....Both of mine cracked from age last summer.
CRH is offline   Reply With Quote
Old 08-11-2016, 03:50 AM   #12
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
My photos are always upside down. I have to crop them just a bit, save that copy and then that will post correctly for me.
You could try that.
Plumbing is next on my list so I will be watching what you do here.
Good luck!
Dingo Girl is offline   Reply With Quote
Old 08-11-2016, 04:03 AM   #13
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
..... hate it when that happens...sore neck.
Above floor....is the floor wet & stinky?
Grey tank hose & clamps
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-11-2016, 08:54 AM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
Thank you Cloudsplitter for correcting the view of reality.
Yes, tried rotating and retaking image. Upsy Downsy might be related to a new photo program.
Floor is dry but odor coming up from the tank area. No grey tank. No apparent grey water hose leaks.
Will pull the dump valve next. No apparent leaks from valve body, But a leak in the adapter (as mentioned by CRH and Sealaker above) could be the problem. Will keep you posted. Signing off for now as my dog insists on helping me type.
Black tank blues Chae Waste Systems, Tanks & Totes 3 10-21-2016 04:08 PM
Hard Water Blues cooney Fresh Water Systems 13 12-26-2007 06:31 PM
Thetford one pedal no water blues handn Sinks, Showers & Toilets 7 12-26-2005 05:38 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
