Old 06-04-2008, 09:50 AM   #1
1973 25' Tradewind
Spearfish , South Dakota
Black water back up
Black water is backing up into the shower in our '73 Trade Wind Land Yacht and it's leaking badly out through the skin in that area too. When we put water into the black water tank to mix chemicals it holds just fine but when water comes through the drain it somehow backs up the blackwater.
Any ideas?
Spearfish, SD
Ketchum is offline   Reply With Quote
Old 06-04-2008, 11:43 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
From what you describe, it sounds like:
1- you have a leaking dump valve, and
2- you are leaving the drain cap on the trailer.
Your trailer doesn't have a grey tank, so the black water would back up directly into the shower when the drain pipe fills.
Old 06-04-2008, 01:25 PM   #3
1973 25' Tradewind
I can't find a drain pipe other than the black water drain and the black water dump valve is broken so I can't leave that off. Is the gray water supposed to drain through that same drain?
Old 06-04-2008, 02:27 PM   #4
1972 25' Tradewind
Rogers , Arkansas
Look up your dump pipe. If there is a small diameter pipe coming into the larger pipe after the dump valve, you don't have a grey water tank. If you don't have a grey water tank, you must remove the drain cap on the dump pipe to allow the grey water to drain.
I have a wet bath model and had a problem with back up into the floor of my bath when traveling. I purchased a drain plug similar to those used on boats. I plug the shower drain, it's in the bathroom floor, and it solved the problem. Your shower drain is the lowest drain in your grey water system and any back up will usually occur there first.
Preston and Marilyn
AIR#809
pepper48 is offline   Reply With Quote
Old 06-04-2008, 02:34 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
You say that the black water dump vale is broken. Is it broken open or closed?
In the Globetrotter, also without a gray tank, both sinks and tub drain into the fitting where you attach the sewer hose. If the dump valve is closed what ever goes down the drain backs up into the tub that is the lowest open point above the collector. I did this the first few times after I first got the trailer. It looks worse than it is.
If you can open the dump valve the gray water will drain into the black tank.
Run fresh water down one of the sinks and close the valve if you can. This will make hooking up the sewer or Blue Boy a bit less nasty.
If the valve is stuck open then the tank may be full or obstructed. This is were things get messy.
Hope you find this helpful.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-04-2008, 04:42 PM   #6
1973 25' Tradewind
waynesboro , Virginia
If your 73 Land Yacht is similar to mine, you have no grey tank, supposedly 74 was the year for both (beginning), a local repair shop told me to alway keep a plug in the shower drain, that will keep the black water from backing up,,,,another strange thing, the grey water will, at times drain to the ground, depending on how you have hooked up your black water drain, and it apparently was designed to work this way....we always take a blue boy along, some places don't want the grey water draining on the ground, although some do, particularly the southeast where it has been so dry....
waltero is online now   Reply With Quote
Old 06-13-2008, 08:32 AM   #7
1973 25' Tradewind
It is as you people say. I took the cap off and it works fine. I even found that the dump valve is working for the most part. It leaks a little bit but not too bad. I just need to find why it leaks at all.
Thanks everybody! I'm a newbie and I'm finding that I know even less as I go on.
Spearfish, SD
Old 06-13-2008, 09:26 AM   #8
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Ketchum,
From the sounds of things, you need to update your profile..."Currently Looking..."
Gongrats on the trailer and getting a solution to your drain problem.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 06-13-2008, 09:58 AM   #9
1973 25' Tradewind
Good point! I'll do that right now!
Spearfish, SD
black tank, leaks
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
fresh water and black water capacity 64tr0tter Fresh Water Systems 4 10-28-2007 09:24 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Richard Vroom Our Community 6 09-03-2003 07:19 PM
