Old 02-04-2015, 01:26 PM   #15
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Downside to the Sewer Solution
After 4 years of happily using the Sewer Solution I finally found one downside.
The weather outside was 28 F. The slab is concrete. The SS is a roller coaster - down to the slab and back up about 3 inches to the drain. The "river" froze over at night... My morning shower left 4inches of water in the bottom of the shower.
It's lucky I like a HOT shower (I could almost poach eggs at the temp. I like). By the time I got out, dried, dressed, etc. I heard the giant sucking sound as the Ice in the SS gave way.
Paula
Foiled Again is online now   Reply With Quote
Old 02-04-2015, 06:34 PM   #16
chaseav's Avatar
2015 25' FB International
No worries on the picture. Just next time maybe! Do you use some sort of quick(er) disconnects between the sections of pipe? My SS came with an extra 10ft section of their hose so I probably don't need much more. Might just end up buying a 20ft section and not having to mess with the rest.
chaseav is online now   Reply With Quote
Old 02-04-2015, 07:40 PM   #17
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I connect the pieces of PVC with standard double female connectors. I do not glue them. they stay tight and do not leak, but I can easily separate the pieces for storage.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 02-04-2015, 08:14 PM   #18
chaseav's Avatar
Paula, what sized hot water heater do you have? Is it able to keep up with your... demand?
Old 02-04-2015, 08:19 PM   #19
chaseav's Avatar
Good point Brian, there really isn't much pressure to deal with. I found 25ft of Valterra hose for $45. I'm going to wait to see if I really need it but I think that's how I'll go depending on how hard it is to straighten out.
Old 02-05-2015, 05:35 AM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by chaseav View Post
Does anyone have a good rule of thumb for a good amount of time that's necessary (both minimum and maximums) in between tank dumps? We're going to be using our new "ship" for a couple days, on and off for the next couple weeks and I doubt producing enough... black water... to merit a dump based on volume and capacity. Should we dump regardless? Do people usually dump and flush after each trip?
I ordered a Sewer Solution and plan to use it, plus I have the tank flush hookup as well. Obviously I'd like to mess with this as seldom as often though!
I guess I'm looking for a "dump your black tank when it reaches 50 out of 60 gallons or every X days, whichever comes first."
Thanks in advance!
chaseav,
Our solution
We don't use a SS and are able to dump at home.
Old 02-05-2015, 06:13 AM   #21
Standard 6 gallon. I did replace the shower head with a water saving Oxygenics head. And I rarely dawdle long enough to run the tank out.
Paula
Old 02-05-2015, 06:41 AM   #22
moosetags's Avatar
Paula
We also use the Oxygenics shower head in Lucy. We also have added an in-line cut-off valve at the base of the shower head. Our Oxygenics is about seven yrars old and now in its third Airstream. We have found that this give us a strong shower feel with reduced water use.
Brian
Old 02-05-2015, 10:24 AM   #23
gpt
2014 25' FB Flying Cloud
sequim , Washington
good friend who has been towing for about 40 years, finally came to the conclusion, about 10 years ago, that not putting TP in the tank was the best solution to not clogging things up. we just use a plastic bag in the head which we dispose of each day.
i also find that the black water tank does not fill up as quickly as the gray water tank but if i have a sewer connection available, i'll dump before i leave. the water flush on the black water tank should keep everything clean and tidy. i also use chemicals in the black water tank if for nothing else to reduce the odor.
gpt is offline   Reply With Quote
Old 02-08-2015, 05:03 PM   #24
1981 31' Excella II
New Market , Alabama
The type of TP matters a lot as well. That thick fluffy stuff that women like has more wet strength. Scott TP seems to dissolve well. Experiment with wet TP in the sink and you will find out what falls apart better.
Perry
How often to dump black water tank plmulhern Sprinter and B-van Forum 30 04-24-2015 05:20 AM
How often do I need to dump? BoldAdventure Waste Systems, Tanks & Totes 32 09-11-2014 09:49 AM
Empty black water / greywater tanks dump valves kdufour Waste Systems, Tanks & Totes 3 09-30-2013 07:46 PM
How often to inspect Propane tanks? 3campers LP Gas, Piping, Tanks & Regulators 6 07-02-2013 04:39 PM
How Often Do You Dump the Black? KJRitchie Waste Systems, Tanks & Totes 66 04-23-2013 11:30 AM
