Old 04-25-2016, 06:07 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Black tank vent fan
Anyone have experience with one of these?
http://www.lslproducts.net/IL-DSPage.html
KYAirstream is offline   Reply With Quote
Old 04-26-2016, 03:09 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Seems to be a good idea. However, thinking of some Airstream models, there are two tank vents, gray and black, so there would two units needed with twice the power consumption..
switz is online now   Reply With Quote
Old 04-26-2016, 05:06 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Do you smell stink?... AFTER repairing the factory vent install we have been stink free.
If you have a stink there may be a problem.
As far as the vent fan goes I prefer KISS...
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-26-2016, 05:50 AM   #4
Black tank vent fan
I get an odor sometimes when flushing. It's especially noticeable if the foot pedal isn't snapped back right away. I replaced the vent cap with the Siphon 360 hoping that would help, but no change. This happens with no fans running. I wonder if it's because my toilet sits directly over the black tank?
Old 04-26-2016, 06:08 AM   #5
richw46's Avatar
Lexington , Kentucky
We were getting a smell we thought was coming from the black tank but turned out to be the gray. When the Fantastic Fan is on we make sure to close the vanity sink drain. We've flushed out the gray tank several times, which helped, but we still close that vanity drain.
In our storage compartment there is a device on the gray water line from the kitchen sink. It looks to be some kind of vacuum break maybe??? Since it sits right under the bed we get a whiff of gray water tank smell from time to time at night. I'm going to insulate around the PVC pipe better to keep the smell from coming into the AS. (You can see interior light where the pipe goes through the wall. The pipe is visible inside the trailer between the bed and the shower wall.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 04-26-2016, 06:33 AM   #6
Sounds like you need a new air admittance valve. If you insulate and seal up around it, then the valve won't be able to do its job. Fortunately it's a cheap and easy fix.
Old 04-26-2016, 07:42 AM   #7
Thumbs up
Used to use olive.. but 1/4 cup of Crisco in the bowl over the Winter has kept the seal subtle and the flap closing.
Stopped putting RV A/F in the bowl 3 years ago after developing a leak & replacing the valve assembly.
PFC
RLC
Old 04-26-2016, 08:08 AM   #8
richw46's Avatar
Great! Thanks for the information. Are there more than just the one in the storage area?
Looking at Amazon there are a lot of different brands, numbers, etc. Is this something that is stamped on the valve itself? I have a plumbing schematic for the 23' and neither it nor the owner's manual lists that part.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-26-2016, 08:09 AM   #9
Black tank vent fan
Haven't had trouble with the flap closing, but that's a great idea.
Old 04-26-2016, 08:11 AM   #10
For the air admittance valve I'd just remove the existing one and take it into Lowes or Home Depot and get whatever they have with the same diameter fittings.
Old 04-26-2016, 08:23 AM   #11
richw46's Avatar
Thanks, I'll add it to my list of things that need work (sigh)
-Rich
Rich & Yvonne
2004 4Runner SE
Old 04-26-2016, 10:01 AM   #12
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I replaced both of my vent covers with 360 Siphon RV Fume Extractor and they work really well. When our Airstream was in storage you could always smell the black tank after each use outside the Airstream. I even noticed it camping once. When I replaced the vent with the Extractor the smell after use when completely away. Highly recommended. It does what it says it does.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-26-2016, 10:05 AM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Similar is this one, with a solar-powered vent fanÖ
http://www.amazon.com/nicro-Stainles...cro+solar+vent
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-26-2016, 07:09 PM   #14
I put on the Siphon 360's as well and they appear to be a good design, but aren't cutting it for some reason.
That solar vent looks like an interesting option as well.
Fan-Tastic vent fan cover C FORD Roof 11 12-09-2015 12:47 PM
Black tank vent snapped off at tank! russ240 Sprinter and B-van Forum 14 08-12-2015 06:38 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
