Old 08-07-2017, 09:34 AM   #1
Randy
Randyf22's Avatar
2015 27' FB International
Portland , Oregon
Black Tank Valve Binding
The black tank valve on my 2015 27 ft International takes much more force to open and close than the grey tank valve. The valve does not leak. Does anyone have an explanation have a similar situation?
Can anyone offer an "anatomy of a valve" or direct me to a detailed discussion on valve construction, removal/replacement.
Randy
Randyf22 is offline   Reply With Quote
Old 08-07-2017, 10:20 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Basically just a simple slide valve - ie a blade that runs back and forth in a track when you
pull / push the operating lever. There will be rubber seals that bear against the blade to stop it leaking and Maybe these are sticking
You can buy a commercial product (Thetford?) which is a slide valve lubricant - not sure how well it works. Some folks - me included - just throw some veg. oil . in the toile t now and then for the same purpose.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-07-2017, 10:25 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I add Calgon water softener to the tank with water in it, to keep the seals fresh.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 08-07-2017, 01:41 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I would also go the vegetable oil route.
CRH is online now   Reply With Quote
Old 08-07-2017, 02:14 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 2008 Classic 25fb black tank valve sticks a little compared to gray. Last year tried the water softener trick and it seemed to help but after winterizing with antifreeze it started out sticky again. I might try it again put it isn't so sticky that I'm thinking something will break.
Kelvin
Old 08-08-2017, 12:17 PM   #6
fth
2003 39' Land Yacht XL 330 hp w/2slides
Fairlawn , Virginia
I had this problem with our previous 2005 AS Classic 30. I replaced the valves and in so doing I think I know why none of these solutions work. Grit gets behind the valve and can't be cleared from the upstream. I "think" I would try running a hose up the discharge from outside until it got to the valve and then run a strong stream of water while operating the valve to flush out the grit. If that works then you have saved yourself one heck of a lot of work because replacing that valve while laying on your back in the grass is a bear. Let me know if that worked. I didn't try it because by the time I think I saw the problem I had the valve out and just replaced it. BTW my worry is that where the rod that moves the valve connects to the plastic slider it might break and either leave it open or closed.
fth is offline   Reply With Quote
Old 08-08-2017, 01:02 PM   #7
2012 25' FB International
Evanston , Illinois
I sprayed the rod that goes into the valve body with silicone lube. That made it much easier to operate. Then I adjusted the length of the handle rod so the handle went into the proper position when the valve was closed. Problem solved!
Hi-Ho Silver!!
JerryMcMunn is offline   Reply With Quote
Old 08-08-2017, 07:41 PM   #8
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Here are two videos that do a good job of showing what you can expect the job to take if you have to replace or repair instead of just lubricate. The first one is the RV Education 101 series that I have gotten some great general information from.
2013 Ford Expedition
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 08-14-2017, 08:09 PM   #9
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Randy
Yah! I have the same problem. No answers yet to free it up successfully.
Veg. oil didn't do the trick.
MelGoddard is offline   Reply With Quote
Old 08-25-2017, 08:19 PM   #10
Randy
Randyf22's Avatar
Portland , Oregon
I lubricated the shaft and threw valve lubricant into the black tank. Significantly better now. Thanks guys!
Old 10-10-2017, 06:05 AM   #11
Randy
Randyf22's Avatar
Portland , Oregon
We have been on the road since 21 August. I began dumping a 1/4 cup of Dawn into the black tank via the toilet prior to departing camp. This seems to help the valve significantly.
Old 10-10-2017, 09:52 PM   #12
2007 22' International CCD
Try slightly loosening the bolts that hold the valve together. If that makes it easier to slide open and shut without leaking, it was probably over tightened.
Replace the original nuts and also bolts if possible with stainless steel. Use the nylon insert self locking nuts and tighten gently. Big box home stores have them in assorted sizes in the hardware department. Those nuts will not fall off if you donít tighten them to death like an ordinary nut. Adjust for smooth open/close and not leaking
KE4GNK/AE
Old 10-23-2017, 10:07 PM   #13
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Anyone try this:
https://m.youtube.com/watch?utm_camp...m_medium=email
Troutboy
Troutboy is offline   Reply With Quote
Disc brake slide binding beetlebob Brakes & Brake Controllers 8 11-25-2015 04:09 AM
Loss of Control From Brake Binding? FlyinNitwits Brakes & Brake Controllers 54 10-31-2015 12:52 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Black Tank Valve Repair 87MH Waste Systems, Tanks & Totes 4 01-27-2004 06:47 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
