Old 06-15-2011, 06:58 PM   #15
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Welcome back! I had hoped to see you when I was supposed to go to 4CU Rally. The trip got cancelled to have Gall Bladder surgery. Gall Bladder surgery got cancelled to attend my Fathers Funeral.
Back to your problems.
The toilet seal to the flange may have dried out. Your vacuum relief valve for your sink may have failed. If you have an O-ring in the toilet it may have a cut or shunk.
Glad you have a new SO as well.
Happy Camping.
Michelle TAC MT-0
Sarah, Snowball
Old 06-15-2011, 08:04 PM   #16
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
We just had this problem...two days ago. It smelled so bad I almost passed out in the bathroom or threw up.
After doing some online research, we dumped the tank containing the chemical helpers. Flushed it twice with water. Filled it 1/4 with water and dumped half a box of baking soda. Let it sit over night and the smell has almost completely gone.
We quit using our vent fan which seemed to create more of a problem. We also quit using the toilet additives.
We plan on putting more baking soda and 1/2 tank of water when we move this week. Hoping it will slosh around and help clean out the tank some more.
Not sure if this will be a "permanent fix" or not, but it is working so far.
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
Old 07-25-2012, 08:21 PM   #17
M. Smith's Avatar
2012 25' Flying Cloud
Tuttle , Oklahoma
Did you ever get the problem resolved? I'm having the same issue - odor is strongest in the closet and under the sink. I've cleaned, checked the vent, the seals on the pipe, the toilet tank, etc. etc.
M. Smith is offline   Reply With Quote
Old 07-26-2012, 12:29 AM   #18
2005 19' Safari
GLENDALE , AZ
M. Smith,
See links below for more current discussion threads on this subject:
http://www.airforums.com/forums/f444/stinky-93852.html
http://www.airforums.com/forums/f483...eam-93646.html
http://www.airforums.com/forums/f444...ml#post1169489
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 08:27 AM
Need Black Tank Information! Janie Q Waste Systems, Tanks & Totes 6 06-07-2011 03:40 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
