Old 06-05-2013, 08:40 PM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is there a "sensor" tutorial?
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 06-06-2013, 01:01 PM   #16
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by rperrym View Post
Yes, it was a very good patch, which I don't notice unless I crawl under the trailer. This is not what I wanted on my new trailer, but it has been done before as posted on this forum.
Rick
Next time you are under the trailer is their a way you can shoot a photo or take measurement on how big the patch is and where it starts from the forward and dump valve side of the sheet metal pan. With this patch does it look you could access both the gray and black sensors?
Kelvin
Old 08-04-2013, 05:19 PM   #17
KJRitchie's Avatar
2008 25' Classic
My black tank sensor is acting up again. Reading full when it's empty. I tried adding a bog of ice cubes down the toilet then driving home but its hasn't changed the reading. When it happened before the ice cube trick worked and on the next trip the montior panel read correctly. When putting the AS back in storage I was able to fill up the tank until until full and noticed the panel read full. Then drained and the monitor showed empty. A month later we are on a trip and after a few restroom sessions the tank sensor showed almost full. I ran the black flush so the tank was almost full then dumpped but the monitor panel still shows full. Is it toilet paper that is clogging the sensor?
Kelvin
Holding Tank Sensor mrglenn Waste Systems, Tanks & Totes 0 05-13-2008 08:49 PM
Level Sensor - Black water holding tank. mharrison@ie Waste Systems, Tanks & Totes 3 12-31-2007 06:09 PM
05/25' Classic Black Tank Sensor Probe KANEHILL Waste Systems, Tanks & Totes 1 10-06-2007 01:18 PM
Water tank Sensor locations..... leefields Plumbing - Systems & Fixtures 1 02-17-2006 11:16 AM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
