Old 10-06-2003, 10:23 AM   #1
Question Black tank repair
I have the tank out!!!!!!!!!!!!!! I have the rear bath so the tank sits above the subfloor. Does anyone have experience with using patch on a black tank. I have a 3 inch crack along the side where the probes are and I'm thinking about using a kit that is made for this purpose. Will it work and hold????? I've gone to to much work to get to this point to just experiement. I hope someone can give me help.
Al
alori is offline   Reply With Quote
Old 10-06-2003, 11:56 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Is it a fiber glass or a plastic tank? Fiberglass is no problem to repair. Just need to sand it back to clean material and reglass that area.
Plastic might be a problem. ABS and some other plastics do not glue very well. There are tricks including flame treating the surface to burn off impurities so it will bond with the adheasive.
What your is the coach? Have you been to www.inlandrv.com Andy has some tanks available for older units and might have one for yours.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Black Tank Valve Repair 87MH Waste Systems, Tanks & Totes 4 01-27-2004 06:47 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
how long to fill black tank? Stefrobrts Waste Systems, Tanks & Totes 11 06-30-2003 11:14 AM
