Old 08-17-2003, 07:31 PM   #1
Deluxe21's Avatar
Images: 24
Black tank Problem
I had a leak coming from the toilet so I removed it to find a large problem. The fitting that seals the tank to the toilet has rotted away. Is this able to be replaced or am I in need of a new tank? I think the tank and toilet are the original units and would like to keep them if possible. The tank holds water and the toilet works fine so all I need to do is get them together somehow. The hole is quite a bit smaller than the norm so I don't think the household 3in flange will work. Also I don't know if it would use a o-ring, wax ring , or gasket. Any help would be appreciated.
Steve
Deluxe21 is offline   Reply With Quote
Old 08-17-2003, 07:49 PM   #2
Silvertwinky's Avatar
South Shore , Kentucky
Deluxe21,
If I remember correctly, when I took up the floor on our 68 Safari; the part that sits above the floor screws into the tank. This might be the case with your fitting. If it is then you might be able to unscrew it and then you just replace it with a newer part.
Visit our church on the web!
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 08:42 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
how long to fill black tank? Stefrobrts Waste Systems, Tanks & Totes 11 06-30-2003 11:14 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
