Old 07-16-2015, 09:33 PM   #1
1998 25' Excella
Temecula , California
Black tank pipe
My pipe from the black tank is slow to the ground it drags on each driveway, it just got torn off on a grass hill. Is this common
dmccullough is offline   Reply With Quote
Old 07-16-2015, 09:42 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Man, that's a bummer...
Really sorry your first post was because of a problem...
uh... well, when you pull over uneven surfaces, it is possible to 'drag' the understructure. (you already know that is 'bad'...... What shape are your axles in?
To check, look at the angle 'down' you see from the axle to the spindle...go ahead, peek underneath...
Now, how much 'load' do you have in the AS? Is it running 'level', nose up or down? If your 'nose'/bow is lower than 'level', it gives more rear clearance... just a bit.. but it will make the trailer towing uncomfortable....same with nose/bow to high...
AS you can see, there is no 'set' answer other than.."Know your towing environment."
Our 34' has a fairly 'low' ride... part of the reason AS are known for 'stability'... low center of gravity... but, you can't drag it places you can a 'toy hauler' without paying close attention to 'terrain'... Heck, I can't even get into many of the 'new' fuel stations because of the 'height' of the entrance....
Give us some pics of the AS, hooked up to the TV, on 'level' ground... and pics of the axle 'deflection'...
Peace and Blessings..
Channing
WBCCI# 30676
Sealing drain pipe to black and grey tank bmklawt Waste Systems, Tanks & Totes 5 10-12-2019 06:12 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Easy fix, or not? Black tank/outlet pipe leak Bex Waste Systems, Tanks & Totes 0 09-06-2010 02:03 PM
drain connections, black pipe, etc Chuck Waste Systems, Tanks & Totes 6 04-08-2004 03:45 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
