Black Tank Bottom Fitting: Threaded or Bonded? 1970 Caravel
As it turns out, the original white ABS Thetford mounting flange at bottom of black tank was a slip fit with hose clamp. The tank is Polyethylene just has a green tint to it. I used a RotoZip to cut the four corners off of the mounting flange so that I could spin (still thought it was threaded in) the flange out of the tank due to the plywood surrounding the flange was cut tight around the flange. Once I cut the four corners I could feel around above the flange and discovered the hose clamp. Used the RotoZip again to cut the rusted screw and pulled out the flange.
I have ordered a new Valterra valve, valve flange and collector. Just hope the collector aligns up the 2" gray waste line once installed. Not such a difficult project but it does require a bit of research and this forum was very valuable information to have.
