Old 11-08-2015, 05:44 PM   #1
Hack
1981 25' Excella II
Mesa , Arizona
Black tank outlet crack
Hi, All.
I recently purchased a 1981 Excella II 25 footer with a front kitchen. I've had a few Airstreams in the past but I've never seen this floor plan. I really like it. It will need some restoration but I plan to keep it a long time so I want to do the best I can.
First project is the waste system. It was dripping at both Thetford valves and from the black tank outlet where the PO "fixed" it with electrical tape. Not!!!!!
The black tank sits above the floor in the rear. The outlet drops from the bottom through a hole in the floor.
There is a 3" abs elbow that slips into the outlet. The outlet has a 1-2 inch crack causing the leak. I attempted to plastic weld the crack with the tank still installed but when fitting the abs pipe into the outlet it split apart again. When the pipe is installed the crack is pretty wide.
So the question is; has age caused the plastic to shrink? Is there a way to repair this or do I need to replace the tank?
I appreciate any advice.
karisk12 is offline   Reply With Quote
Old 11-08-2015, 06:30 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It could be repaired, I am almost sure of that, however, the easiest, surest, and maybe even the cheapest fix might well be a new tank from the get go.
Brevi tempore!
Old 11-08-2015, 06:50 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Brevi tempore!
Fix it, don't repair it...if you want to try to repair.... Have you thought of epoxy??? Might work..b there are some real exposures.. Not the store brands..
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-11-2015, 06:15 AM   #4
Hack
1981 25' Excella II
Mesa , Arizona
I removed the tank over the last 2 evenings. I called Airstream and they had no information on an above floor tank in 1981. I'd sure like to see a manual for that year. I had to remove the toilet, sink, plastic countertop, sink cabinet and plastic cover over the tank to get to it. I was expecting rivets but it was all screws. Further disassembly of the cabinetry and closet would have been all rivets but it was unnecessary. There was one hidden screw that had no access and caused me to break a 1" piece of the countertop. It will be hidden again so I'm not worried about it. I consider myself a mechanic not an artist or carpenter so I plan to put it back together the way it was. The tank is very unique and I can't find an exact replacement. Now that its out I'll try again to repair it or take it to Phillp's Plastic in Tempe where they've quoted me $125-150 to repair it.
Old 11-11-2015, 07:46 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Plastic repairs can be tough. You really want to find the solvent that works. I take a paper towel and rub acetone on it, and then rub that on the tank. That'll tell you fiberglass vs polyethelene vs some type of ABS. If ABS, it will soften and stick to the towel. Polyethelen will be whitish usually, and you should be able to see some glass in fiberglass. Its probably an ABS type material. I would get a polyethelene bottle, like a glue bottle and squirt it in the crack to clean it (after you've tried blasting it with water and soap and rinse) then, look for some extra plastic - like at a seam, or flange or something and scrape that into a glass jar, then mix with acetone or MEK to create a paste. Use that to fill the crack. I would widen it first, then fill, then compress, and leave the squeezeout there until cure, and leave it if it doesn't cause a problem. there is also this great new tape at Lowes and HD that has a curing component in it - they sell it in the plumbing section. Not sure where the issue is on your trailer. The other option is after the repair, scuff up the plastic, then wrap in fiberglass and glass it. I've had fiberglass bond very well to ABS in my trailer for some plastic parts - like a cover piece that was in a closet.
robwok is offline   Reply With Quote
Old 11-11-2015, 08:00 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Tank color should tell you the material. Black is ABS, milky white is polyethylene. Best repair method is to use parent material combined with a solvent which will cure and be as strong as the original.
BambiTex is offline   Reply With Quote
Old 11-12-2015, 05:21 PM   #7
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
I've got the exact same design of bathroom in my 76 Tradewind. Black tank on top of floor. My tank cover cracked so I'm looking at a job just like yours only stopping when I get the cover off.
terrencecolp is offline   Reply With Quote
Old 11-12-2015, 05:37 PM   #8
Hack
1981 25' Excella II
Mesa , Arizona
I will be happy to share my lessons learned. Send me a picture so I can see if it's the same
Plastic Welding 310 MH Black Tank Outlet Auretrvr Waste Systems, Tanks & Totes 4 08-02-2014 07:54 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Easy fix, or not? Black tank/outlet pipe leak Bex Waste Systems, Tanks & Totes 0 09-06-2010 02:03 PM
What glue should I use to fix a small crack in my freshwater tank? JimGolden Fresh Water Systems 4 06-11-2009 04:22 PM
Argosy holding tank crack blondie3265 Waste Systems, Tanks & Totes 8 07-14-2007 11:09 PM
