Old 09-17-2016, 03:52 PM   #1
dasams's Avatar
Palm Desert , California
Black Tank Level Rises without Use?
We are parked in my brother's driveway under shore power, city water but no sewer hook-up. When we arrived, our black tank was at 75% so we've been using his facilities. After two days, the level has risen from 75% to 94%. Can anyone explain how this is happening?
We leave tomorrow and I'd like to avoid hitching up to dump the tank this afternoon. Also, how much reserve do we have above 100%?
We have a new 2017 FC 25.
TIA, Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 09-17-2016, 04:00 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi. A few guesses:
1) your monitor is not adjusted correctly. Have you looked down the hole? At 94% you should be able to see water pretty high up the pipe. There should be a shutoff on the feed to the toilet so when you open the flapper you're not demanding water.
2) if your water pump is on and you're connected to city water, you may have a leak (have you heard the pump kick in?)
3) your toilet bowl/flapper seal isn't tight
4) your bathroom sink may drain to the blank tank (apparently that happens in some models - not sure if yours is one of them).
Good luck!
Old 09-17-2016, 04:19 PM   #3
dasams's Avatar
Originally Posted by SteveSueMac View Post
Hi. A few guesses:
Thanks and bingo! I just read my owner's manual and some, but not all, models drain the lav sink into the black tank. This was good to learn so that I can better manage my tanks.
Thanks, Dave
2018 FC 27 FB
2017 FC 25 RB Gone
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 12:21 PM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 07:39 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 04:52 PM
Replacing black and gray tank level indicators nickcrowhurst Waste Systems, Tanks & Totes 4 12-30-2003 09:42 AM
