Old 08-04-2009, 09:30 PM   #1
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
Black tank leaking
Help! 74 Ambassador rear bath. Black tank is leaking (dripping) when it gets above 3/4 full. Doesn't give any problems below this level. Any ideas? I will check replies tomorrow as it is late.
bimpy is offline   Reply With Quote
Old 08-13-2009, 01:24 AM   #2
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
Hi,
I have a '74 Overlander that has the same bath configuration as yours. The black tank also leaked like you describe. I removed the toilet and used a mirror (One of the small ones with the telescoping handle that you can buy at an auto parts store) to look around the inside of the tank. I found a large crack, about 8 or 9 inches long, that ran from the top of the tank and down the side. After reading about black tank repairs on the forum and consulting with someone who had done this kind of repair, I decided to tackle the repair job myself. I used Scotchweld 8500 (search Scotchweld on this forum) to glue the crack back together. It filled the gap and bonded so well that I knew it was going to hold even before I tested it. And so far, no leaks! I am very confident that this repair will hold.
To do this job correctly, it is necessary to remove the tank.
Hope this helps!
Curt
somefun is offline   Reply With Quote
Leaking Black Water Tank ssolid Waste Systems, Tanks & Totes 6 04-10-2009 07:26 PM
Factory black flush tubing leaking casarodante Waste Systems, Tanks & Totes 8 01-28-2009 10:47 PM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
freshwater tank leaking rec Waste Systems, Tanks & Totes 4 01-07-2008 12:30 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
