Old 09-28-2010, 11:20 AM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Black tank leak? I'm in a blue funk!
I've looked through the most recent dozen pages of threads in this sub-forum and can't find anything on leaking black tanks in units similar to the age of ours (1999 30' Excello). We bought it from the original owners in 2006 - it had sat unused for 3 years.
Which makes me wonder what is the nature of my problem. Given the difficulty of discovering it, I thought I would see if anybody here might have suggestions.
Like many, I've had occasional problems with a 'trickle' leaking blackwater valve - discovered the hard way when you remove the pipe cap. I've always managed to resolve it by repeat flushing or, if that didn't work, snaking a garden hose (with the tip set to wide-spay) backward up the drain pipe. That seems to always do the trick.
But my current problem came about last weekend. We spent the weekend at a campsite - no problems, no smells, no leaking tank. Before we left, I flushed carefully (triple flush) since it had gotten little use, there wasn't going to be a big FLUSH, and I wanted to make sure no TP got stuck in the valve.
After a short 1hr drive home, I realized I hadn't put in a blue-pack with water... so I did.
The next day, preparing to take the unit back to storage, I saw a large (and smelly - you know that blue-pack smell!) stain on the ground. Looking under the trailer, the belly pan that contains the water tanks was leaking blue stuff out of the lowest corner.
I removed the pipe cap - no liquid at all, blue or otherwise.
I've never seen pics of the connection of the drain pipe to the valve to the tank (if that's the sequence).
could there be a leak at a pipe fitting, allowing the liquid into the belly pan? Do I need to drop the belly pan to fix this? Any comments (especially from Andy!) would be appreciated.
Signed...
Blue Funk In Texas!
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 09-29-2010, 12:03 AM   #2
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Your manual should show a layout of the gray & black water valves, plumbing, etc. I have assisted on one such job on a trailer a few years older than yours. I was not in on the beginning however.
Once an assessment of the center line and the amount of curved pipe leading to the black tank was made, a piece of the under belly was cut out exposing the two valves and piping to the tanks. In this case, new valves were required which is not much of a job once the opening is cut.
I would fill the tank with plenty of clean water first and be sure I had flushed the line out completely. Then if you are still leaking water thru the belly pan and not building up in drain line against the cap, you probably have a bad valve.
I would call Rick March at airstream in Jackson Center (service coordinator/manager) and have him give me a run down of the repair procedure they follow.
I shudder that sooner or later I am facing the same job.
They cover the opening with a new piece of galvanized sheeting and inch or so larger on each side. I would also caulk the edges.
Not much help I know. Best of luck.
wingfoot321 is offline   Reply With Quote
1971 Airstream leaking blue liquid from black tank svachon Waste Systems, Tanks & Totes 3 09-19-2012 12:02 AM
Black tank leak NicheVintage Waste Systems, Tanks & Totes 5 05-14-2010 06:39 PM
My Black tank leak thecatsandi Waste Systems, Tanks & Totes 16 01-15-2008 08:29 PM
Black tank leak soldiermedic Waste Systems, Tanks & Totes 2 11-26-2006 09:03 AM
Black water tank leak $$$$ wacnstac Waste Systems, Tanks & Totes 6 05-08-2006 10:50 AM
