Old 11-25-2006, 09:46 PM   #1
soldiermedic's Avatar
Florissant , USA
Black tank leak
Greetings all,
Before I had the shop take away my trailer for a new frame and floor, I wanted to ensure the black tank was empty (the PO told me it was, but I wanted to make sure). I took a 5 gallon bucket and dumped it down the toilet. My T-handle was in the closed position, but there was an ever so small trickle of water coming out the drain connector. I pulled the T handle and whoosh...no brown trout, just water. I am concerned about this as my black tank is unuseable unless I have a full hook up. Is it most likely the t-handle valve? Is this easily replaceable?
SM
soldiermedic is offline   Reply With Quote
Old 11-26-2006, 04:05 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Sounds like your dump valve (probably a Thetford SLIDE-EZ) is at fault.
Parts are still available.
Tom
Old 11-26-2006, 09:03 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Now why would you have to call them brown trout? Couldn't they be catfish or bullheads, afterall, they both are bottom dwellers.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
