Old 02-28-2015, 05:21 PM   #1
2011 30' Flying Cloud
Greenback , Tennessee
Black tank flush problem
When I hook up the water hose to clean out my black water tank, nothing happens! There is apparently an anti-back flow valve that is not opening. Has anyone else had that problem? Is it something I should be able to repair/replace? Oops! I should have mentioned I have 2011 Flying Cloud 30.
Gneiss Guy is offline   Reply With Quote
Old 03-02-2015, 05:18 PM   #2
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
BUMP...
Timely question. I have the same issue. (2001 "34 Limited) Been working like a champ forever then all of a sudden today, nothing. Did a little investigating and checked behind the hose connection. There is a spring loaded O-ring "stopper that appears to be there just to stop water from siphoning back out the flush connection. (certainly NOT the issue) That was about as far as I dared disassemble as we are leaving for San Diego tomorrow. I did break out the manual and tried to decipher the plumbing diagrams that came with the Airstream, but they are a bit confusing and dont really seem to match our setup anyway. For the time being we are filling the black tank by running water from the toilet untill the tank is full, then vacating the tank, which works but is not ideal. I'll tear into it further in a week when we return.
I figure there must be an inline check, or backflow that has failed. I do still have water everywhere else that I need it just no black flush.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
Black Water Tank Flush Problem Bilo Hak Waste Systems, Tanks & Totes 4 02-15-2009 05:21 PM
Black Tank Flush System Ed & Nancy Our Community 6 02-19-2003 08:36 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
