Old 08-31-2014, 07:55 AM   #1
2009 27' FB International
Silsbee , Texas
Black Tank Flush Leak
The Black Tank Flush inlet where you hook the water hose to flush the tank is leaking inside the wall of our trailer. Water comes out the belly pan just below the inlet nozzle on curb side of trailer. Water makes it into the black tank, but is also leaking at the inlet nozzle behind the outside wall.
Has anyone else had this issue and what did it take to repair. We have a 09 27FB International.
Craig Schrader is offline   Reply With Quote
Old 08-31-2014, 08:00 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There is an anti-siphon valve inside the trailer that lets the air and water out of the back flush when the hose removed. It should be accessible inside somewhere. I would check that first, to see if the diaphragm in the valve has failed. That is a fairly easy fix.
Alan
Old 08-31-2014, 09:16 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I read on at least one other thread in this forum that the backflow preventer for the black tank flush is a POS plastic part that tends to fail. Use the "search function" to find these threads if you are interested in doing further research on this subject. It is apparently fairly easy to get to this valve and replace from inside the trailer. It is apparently just inside the skin of the trailer where the flush attachment is located. You should figure out where it is inside the trailer (based on where the flush attachment is on the outside) and see if there is some panel that you can remove to get to it. I would definitely replace it with a higher quality part and not attempt to bypass it for what I hope are obvious reasons. if you are not handy, and you don't have easy access to an Airstream or RV dealer, a good residential plumber should be able to do this for you.
Bob Martel
WBCCI# 5766
Old 08-31-2014, 10:17 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Anti-siphon valve (lets air in/water out) has a different function from a backflow preventer (stops backward flow).
Look for something like this:
Anti-Siphon Valve
Though, you might have a different type that requires a pipe to be cut and glued or a pex fitting. The one I replaced was threaded.
Alan
Old 09-03-2014, 05:44 AM   #5
Silsbee , Texas
Thanks.
Thanks for the info. I like to gather info before I tear into something.
Old 09-03-2014, 08:02 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
We have the exact same problem but I decided to leave well enough alone. I cannot see any way to get to that fitting without removing the outside panel.
Ahab is offline   Reply With Quote
Old 09-25-2014, 06:02 AM   #7
Silsbee , Texas
Repair Update
To access the backflow preventer (check valve) in our 27 FB International. In the closet behind a step panel ( three screws).
I did not get a picture of the access panel, but it looks like a small step about 6" x 6" in the closet.
I replaced it with a 1/2" threaded elbow and will use a backflow preventer on the end of the hose I use to flush the tank.
Do not let this leak continue. It impacts the floor and furnace blower and associated wiring.
My backflow preventer was a hard clear plastic that developed several cracks.
Also replace the rubber gaskets/washers in the Pex fittings while you have it apart. Total cost about $8.00 A new backflow preventer was between $ 30 and 50 dollars. You can buy brass ones that attach to the end of a garden hose from hardware stores for $10.00.
Old 09-25-2014, 08:19 AM   #8
1998 30' Excella 1000
Livingston , Texas
If the leak is truly just behind where you screw in the hose for the black flush, it could be the fitting right behind it, where the city water also hooks into the built-in pressure regulator for the city water. Ours leaked once, and that is where it came from. But our rig could be plumbed different from yours.
Siegmann is offline   Reply With Quote
Old 09-25-2014, 08:33 AM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Same issue on my preowned 2008 Classic 25fb. The first time I used the black flush water came streaming out the bottom of the trailer while at a full hookup campsite. Broken one way valve. I put an elbow in mine too. I went to an RV parts and looked for a gray elbow piece with the correct threads. I don't really bother with a one way valve most of the time. I use a separate 15' hose for that purpose. The black flush line in mine comes straight up from the tank then make a U turn at the elbow and the then goes back down to the outside connection.
I was able to get to mine through the water pump hatch on the floor of the hall closet. I could reach in and mop up most of the remaining water and let the insulation dry.
The plastic one way valve is junk. Looks like the in the 27 the black tank flush lines are secured nicely. Mine is just wedged in between the shower wall and outside wall. To prevent it from flapping between the outside wall and shower wall I wrapped the line with some PVC pipe foam.
I wonder if Airstream uses this junky part in the 2015s?
Kelvin
Old 09-25-2014, 09:03 AM   #10
Livingston , Texas
While we are on the topic of the anti-siphon valve, I decided to take a look at my OEM fitting (1998). Here is what I have-
Repair Kits for 288A Hot or Cold Water Anti-Siphon Vacuum Breakers - Backflow Prevention - Support
It is solid brass, and the manufacturer offers a repair kit, should it leak. That clear plastic one that cracks with minor aging seems to be another example of Airstream trying to cut costs.
Old 09-25-2014, 09:32 AM   #11
KJRitchie's Avatar
2008 25' Classic
If I had known about that valve I might of used it. However what is the weight of this part? My black tank piping is not secured by a bracket like in the previous photos.
Kelvin
Old 09-25-2014, 09:43 AM   #12
Livingston , Texas
Mine is also secured by a bracket. Based on its size, the valve probably weighs about a pound or so.
Old 09-25-2014, 11:05 AM   #13
2016 30' Classic
Erie , Colorado
Two different type of valves. The plastic one is for the black tank flush, no resistance, straight flow thru. The brass is likely on the main water line for the trailer. That is under pressure when not running so makes sense that it is more robust.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-25-2014, 03:23 PM   #14
1974 Argosy 20
Kooskia , Idaho
Also, everyone who has this black tank flush system should be sure to remember to blow it out with compressed air or pump RV antifreeze through it when you winterize your unit. Freezing is probably the reason many of them have failed to begin with. One just does not think of the fact that water is held in them by a check valve. It will only be eliminated with air or forced in anti freeze.
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
Easiest way to flush black tank? JLD Waste Systems, Tanks & Totes 10 02-19-2003 07:16 PM
Black Tank Flush System Ed & Nancy Our Community 6 02-19-2003 08:36 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
