Old 01-22-2015, 08:21 PM   #1
2015 27' Flying Cloud
maple grove , Minnesota
black tank flush fitting stripped
The plastic black tank flush fitting on the outside of my 2014 flying cloud has stripped making it very difficult to connect a hose. How do I replace it
thebreezeman is offline   Reply With Quote
Old 01-22-2015, 08:28 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
are you talking about the handle you pull to actuate the valve or have the 'ears' broken off?
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-22-2015, 08:32 PM   #3
On my trailer there is a flush valve that I attach a a water hose to when I want to flush the black tank. The female connection on the trailer is stripped
Old 01-22-2015, 09:15 PM   #4
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Wow, that's a tough one. How did that happen?
George
gandttimes is offline   Reply With Quote
Old 01-22-2015, 09:22 PM   #5
Cheap piece of plastic that can be easily cross threaded if the hose isn't attached perfectly straight.
Old 01-22-2015, 09:39 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ah.. well, might be warranty... might..
On my AS, the black tank 'flush' is mounted to a plate. I removed the screws holding the connector then unscrewed the plate it was mounted to. The connector 'unscrewed' from the line going to the tank.
Reverse sequence to replace.
Channing
WBCCI# 30676
Old 01-22-2015, 10:32 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also.... when you buy an inline filter for your 'city water' connection, it comes with a short hose with a spring on the outside so it is 'flexible' but doesn't kink. When you get a 'spare' you can put that on the backwash connection and leave there. Then connect to that ...when you are 'cleaning' the black tank. It will last a long time... just don't put it back on your 'city water' ... it would not be wise..
The advantage here, is that you only need be 'careful' when making the initial connection with the short extension ... then it will be easier to negotiate the connection...
Channing
WBCCI# 30676
Black tank overhaul: Thetford to Valterra tank fitting conversion/ plastic weld rippie Waste Systems, Tanks & Totes 23 02-19-2017 04:19 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
How do you attach the fitting to the black tank? drowe42 Waste Systems, Tanks & Totes 10 07-12-2010 01:07 PM
Slip Fitting On Top Of Black Tank To Toilet Radman Sinks, Showers & Toilets 3 05-02-2007 03:11 PM
63 tradewind black water tank/toilet fitting durans54 Waste Systems, Tanks & Totes 5 04-29-2006 01:16 PM
