Old 07-23-2009, 08:55 AM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
Black tank flush clogged???
Greetings,
I went to clean out my BT using the No Fuss tank rinser installed on our 04 CCD Bambi but when I turned on the water, there was no water entering the tank. Normally I hear the sound of the spray action, but something seems to be clogged somewhere between the outside connection and the tank. In the back of the vanity cabinet, I can see where the flush system enters the trailer
What kind of nightmare am I looking at to get this to work again? If it involves removing any metal underneath the trailer, I'll just resort to using a few 5 gallon jugs to rinse through the toilet.
I always wondered what kept this from getting clogged with something sooner or later.
I couldn't find the company's web site.
Thanks.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 07-23-2009, 09:11 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Originally Posted by crazylev View Post
Greetings,
Thanks.
Jonathan
Jonathan,
Its clogged with TP and poo. My built in flushing device quit working after three months. I bought a flush king. I have been using it since. It works works well.
Michelle TAC MT-0
Sarah, Snowball
Old 07-25-2009, 02:53 PM   #3
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thanks Michelle.
I'll give it one more try and then look into a flush king or hydro flush.
Damn doodies.......
Jonathaan
Old 07-25-2009, 04:06 PM   #4
2000 36' Land Yacht XC Diesel
Middletown , Ohio
When I had a GMC front-wheel drive motorhome I read something about cleaning out a black water tank. They had a message board that was really active and passed around alot of information. They said the best way to clean out the old TP and "poo" was to dump a bunch of icecubes down the toilet and the drive it aqround for a while. The cubes were supposed to scrub out the tank while they were solid and then you could drain them after they melted. Have you ever heard of that one?
David & Peggy Shipley
Middletown, OH
2000 Landyacht XC
dhshipley@cinci.rr.com
dhshipley is offline   Reply With Quote
Old 07-25-2009, 04:36 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would try putting a male quick connect hose fitting on the tank rinse inlet. I would then put some (60 psi) air to it from a compressor with one of those cone shaped rubber fittings on the end of the hose like is used to inflate an exercise ball.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 07-25-2009, 06:45 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
As Brian noted, I have a screw in plug that I use to connect to the city water inlet. It connects to a compressor which is how I blow out the water lines when I winterize. I bet you if you pick up one of those and connect the compressor to it, you will blow out the blockage.
We just used the clean out today before departing for home. So far mine still works fine.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 07-25-2009, 07:47 PM   #7
Cracker's Avatar
Pittsfield , Maine
I second Jack's comment. The flush device on my 2000 Excella continues to work just fine. On the other hand, the sensors have not worked well this season and the tank reads 3/4 full almost continuously. I've stopped worrying about it too much as a simple visual check with the toilet valve held open provides more than enough information! The grey water tank sensors have also been acting up - but what's new? When we don't have full hookups I keep the grey water hooked up to the portable blue tank with the valve open. We seldom need to dump the black water tank before moving on. About the only sensors that continue to work well are those on the fresh water tank.
Cracker
Cracker is offline   Reply With Quote
Help Needed ASAP - Black Tank Clogged sigv Waste Systems, Tanks & Totes 12 09-03-2017 05:14 PM
Black Water Tank Flush neil ervin Waste Systems, Tanks & Totes 13 07-26-2010 02:37 PM
Black tank flush uh-oh silversnail 2007 Safari SE 7 07-26-2010 07:48 AM
Black Tank Flush JmesDean Waste Systems, Tanks & Totes 34 04-03-2006 04:34 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
