Old 03-19-2015, 10:20 AM   #1
jump's Avatar
2013 30' International
lubbock , Texas
black tank flush clog
2013 30' International Signature
I took the trailer in for some last minute warranty checks and repairs, one of which was that the black tank flusher did not seem to be flowing with water into the tank. So, when I picked it up he showed me that the spritzer gadget that is mounted to the tank, from which the water sprays, was all clogged up with, well, the brown stuff that is usually in the black tank.
(why is it not called a "brown lumps-with-occasional-white-flashes tank"?
OK i guess thats too long)
heres the real question: How do I keep this from happening and if it does happen again how do I unclog it without a 2.5 hour labor charge? Is there something that i can run into the sprayer inlet to unclog it?
has anyone experienced this? and how did you remedy?
jump is offline   Reply With Quote
Old 03-20-2015, 10:15 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Regular use will help.
It would appear that you did not flush after your last dump. Otherwise, the crud would have not had a chance to dry.
If you are continuing to use the tank, flushing should not be needed every time, but if you are going to leave the tank dry for any length of time, you should flush it, for the tank and the spray wand benefit.
How to save the labour charges? Fill the black tank, with water, add dish detergent, and let it soak for a day or so. That should work.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Help! BW Clog or Jammed Valve? manda1215 Waste Systems, Tanks & Totes 3 04-05-2015 08:57 AM
Shower drain clog, arggg Sbb Plumbing - Systems & Fixtures 10 01-31-2015 04:54 PM
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
Toilet paper clog willyjay Waste Systems, Tanks & Totes 18 11-10-2010 05:27 AM
Clog in Armstrong a/c coils sobephil Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-24-2006 08:35 AM
