Old 08-07-2010, 10:39 AM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
Black tank flush
The black tank flush on my 94 Excella is not working. Any thoughts on how to get it working? Could it be the vacuum breaker or check valve needs replacing?
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 09-15-2010, 10:10 PM   #2
DesertStream's Avatar
2008 30' Classic
Montrose , Colorado
Did you ever figure this out? We are purchasing a 1994 30' Limited with the same problem.
-Virgil and Sheila
It is not down in any map; true places never are. ~Herman Melville
DesertStream is offline   Reply With Quote
Old 09-15-2010, 10:47 PM   #3
2007 25' Safari FB SE
Eureka Springs , Arkansas
Mine is not working either.
Acts like a valve is closed, no water gets thru system.
triplenet is offline   Reply With Quote
Old 09-15-2010, 11:32 PM   #4
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Whenever I see a thread about black tank flush problems, I think back to the thread, "Black Tank Flush" started by JmesDean in 2006.
When he attached the water hose and turned on the water, he heard a "pop". He thought something popped off and reduced his water pressure. One possibility is that if you attach a hose and turn on the water with too high pressure you might damage the check valve or something else in this "No-fuss flushing system".
So whenever I attach a water hose to my black tank flushing system, I feel the hose as I gradually increase the water pressure to the point where I can see that it is adequately flushing the tank without blasting out the system.
SilverGate is offline   Reply With Quote
Old 09-17-2010, 08:58 AM   #5
PhiDor's Avatar
Smile Need more info
It seems like many of us have this problem. Now if we could figure out how to fix it.....
Phil & Doris Drugge
Black tank flush uh-oh silversnail 2007 Safari SE 7 07-26-2010 07:48 AM
Black Tank Flush JmesDean Waste Systems, Tanks & Totes 34 04-03-2006 04:34 PM
Black Tank Flush Repair AirMax Waste Systems, Tanks & Totes 2 08-26-2005 01:05 PM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
Black Tank Flush System Ed & Nancy Our Community 6 02-19-2003 08:36 AM
