Old 07-27-2009, 11:38 AM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Black Tank Cleanout
A quick history. I bought my Sovereign in 2004 and have been working on it off and on for 5 years. I'm nearly done with all my work and will be using it for the first time on a campout in two weeks. Anyhow, the PO didn't use the black tank properly and it appears she left the valve open all of the time leaving a nice caked on "residue" on the bottom the tank. Any ideas how I can clean this out? Is there some kind of treatment I can use to liquify this residue?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-27-2009, 11:52 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Mike,
Fill the tank 1/2 full of hot water, drive around for a while, drain and repeat.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 07-27-2009, 12:16 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a gizmo I got from CW that is a 2' piece of PVC and a valve. The end sprays out a stream in a horizontal direction to get the stuff out of the corners etc. Cheap and works good.
If you are replacing the dump valve anyway, just reach right up there and pull out the coprolites with your hand while you pretend you are a paleontologist.
Old 07-27-2009, 12:59 PM   #4
c177tx's Avatar
2008 19' Bambi
Images: 20
Place a bag of ice and some salt, in to the black tank then drive around . that is how we clean out the coffee pot except we just shake the coffee pot not drive it around
c177tx is offline   Reply With Quote
Old 07-27-2009, 02:34 PM   #5
Airdaddy's Avatar
1975 31' Sovereign
1969 27' Overlander
Wichita , Kansas
Black Water Tank
Airdaddy Here. From the sounds of things you have spent a lot of money and time to do things right and to fit your personality. I am in the process of doing the samething to my 1975 AS. If I had spent 5 years updating or renewing, I would not do anything other then replace. Then you will have the knowledge and experience on removing and replace the tank. Go all the way and replace. You will glad you did..
Danny
Airdaddy
Wichita, Kansas
Airdaddy is offline   Reply With Quote
My Black tank leak thecatsandi Waste Systems, Tanks & Totes 16 01-15-2008 08:29 PM
Do I have to use the Black Tank? jimsease Waste Systems, Tanks & Totes 8 08-09-2006 10:22 PM
Black Tank Devoman Waste Systems, Tanks & Totes 14 08-02-2006 12:13 PM
Black tank Gunnyusmc All Argosy Trailers 4 07-19-2004 04:42 PM
Black Tank Gunnyusmc Waste Systems, Tanks & Totes 3 07-02-2003 07:38 AM
