09-15-2014, 03:53 PM
Richardson
, TX
Black Tank Capacity
Anyone know the black water tank capacity for a 1971 25' Tradewind Twin? I am guessing somewhere between 10 and 15 gallons but can't find it anywhere in the materials I have.
Thanks.
09-15-2014, 04:53 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
The black tank on my 66 Trade Wind twin bed was a small son of a gun. 10 gal would be pushing it. It was actually pretty well designed in my view, and had a nice foam pad to sit on. It was under a rusted out galvanized pan under the rear of the trailer. But the dump valve and connection point was not at all convenient unless you are fertilizing a farm field.
Here is a photo of a gray plastic black tank. Hope this helps.
David
09-15-2014, 04:57 PM
Richardson
, TX
Wow, that's completely different from my set up. A lot must have changed in those 5 years. My tank sits on top of the deck and the low profile toilet sits on top of that. It's rounded in the back and looks like a quarter circle.
09-15-2014, 05:00 PM
1974 Argosy 20
Kooskia
, Idaho
Most of them were about 12 gal. Can you fill yours with measured gal water jugs to find out, or does it leak?
09-15-2014, 05:02 PM
Richardson
, TX
12 sounds about right. My tank doesn't leak and your idea of measuring the water that goes in is the next step if I don't get an answer on here.
09-15-2014, 05:18 PM
1986 34' Limited
1975 27' Overlander
Conifer
Oops! I wasn't thinking. Senior moment. Airstreams changed significantly in 69. My son's 69 Globetrotter has an above floor black tank in his "wet bath."
David
09-15-2014, 06:03 PM
1987 25' Sovereign
Oregon
, Ohio
On the Airstream.com web site it states that the holding tank is approximately one week in size. What a way to state a size.
09-16-2014, 08:36 AM
Richardson
, TX
I beg to differ on the "one week" size but I think since I have converted the AS to accommodate 2 adults and 4 kids I am beyond what they had in mind when they designed the black water tank. I think we were getting 2-3 days...
