Old 03-20-2007, 07:08 PM   #1
1968 26' Overlander
Sandy , Oregon
Black/Grey water tanks 1968 Overlander
This may be a little bit of a stupid question but can someone tell me what the gallonage is on the black and grey water tanks (if it has both) on my '68 Overlander? I also would like to know what the gallonage is on the fresh water tank.
A diagram of the layout would be most helpful.
I am converting the AS into a different kind of use and part of the process carries some particular requirements of amount of water on hand and waste water capacity vs. fresh.
Any help would be much appreciated.
Stu
StuartM is offline   Reply With Quote
Old 03-20-2007, 07:12 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
no grey tank at all, if it is ''stock" configuration. They didn't start adding them until 1974. don't know the other capacities, but someone will...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-20-2007, 10:37 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
My '66 Tradewind (24') has an 11 gallon black tank. No grey. They did come until '74.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-21-2007, 12:55 PM   #4
Stu
The black tank is about 11 gallons.
The water tank is 30 gallons.
68 Trailers did not have a gray tank.
Old 03-22-2007, 06:43 PM   #5
1968 26' Overlander
Sandy , Oregon
Thank y'all for the info. Kinda figured I would need to add some dirty water holding.
Stu
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
