Old 02-18-2013, 10:56 AM   #1
jornvango's Avatar
Black / grey water hookup while camping
When camping with full hookups, we've been told to leave the grey water hookup open.
Is there a reason why we shouldn't also open the black water at the same time, or does the dumping mechanism not allow both tanks to be opened at the same time?
jornvango is offline   Reply With Quote
Old 02-18-2013, 11:07 AM   #2
dznf0g's Avatar
Oswego , Illinois
Yes, The liquids readily run out and into the sewer while the solids may and will accumulate in the tank as there is not enough rush of flow like at home. Soon you will have such an accumulation that it is a nasty and potentially expensive problem to get the solids out.
I usually don't leave the gray open either if I am doing a lot of dishes with food particles in the dish water. It is for the same reason, but I don't think it would ever plug up....but remaining food particles can become smelly. I like the fast rush of both tanks to draw out as much solids as possible. It's no big deal to pull the gray handle once a day or so and the black handle once a week or so. for me.
-Rich-
Old 02-18-2013, 11:18 AM   #3
Lily&Me's Avatar
Normal , Illinois
The big plus to leaving your grey valve closed is that then you have that relatively clean water to flush your sewer hose.
You can always leave your hose hooked up and just pull the release valves when needed.
We like to get lots of water into our black tank before emptying, to make sure all runs out smoothly.
Maggie
Lily&Me is online now   Reply With Quote
Old 02-18-2013, 11:27 AM   #4
Maggie
Yes, all of this. My gray and black tanks have separate dump openings (since my trailer is old and did not come with a stock gray tank, mine is an addition during renovation). So I leave the hose connected to the gray, but leave the gray valve closed and dump it every day or two. Then, after a few days, I switch the hose to the black tank, dump it, then back to the gray to dump an flush out the hose with "cleaner" water.
Old 02-18-2013, 02:21 PM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
Always keep both grey and black valves closed!
As mentioned above you need to have the black water tank filled with substantial water to allow for flushing out the solids, after which the grey water will flush the black water from the stinky slinky. Additionally, a relatively full grey water tank can be used to “back-flush” the black water tank (if the two tanks are manifold joined as mine are) so as to dislodge solids that may not have flushed out. This is done, after draining the black tank by leaving the black tank valve open, holding the stinky slinky above tank level, opening the grey valve which allows grey water to enter the manifold and move backward into the black tank and then closing the grey valve before the tanks equalize, and then lowering the stinky slinky to allow the black tank to again empty (this can be done several times with a full grey tank).
Additionally, to gain more grey storage on a manifold system, when my black tank is essentially empty and I have a full grey tank I have left the drain cap in place, opened the grey valve which then fills the manifold, and then open the black valve to allow the two tanks to gravity flow ALMOST equalizing, at which time I close the black valve first and then close the grey valve. The only down side to this is when dumping you will spill the manifold contents of grey water when removing the manifold cap, but it can give up to 15 gallons of additional grey storage in a pinch.
withidl is offline   Reply With Quote
Old 02-18-2013, 03:10 PM   #6
1988 32' Excella
Robbinsville , New Jersey
You could add a third valve where the cap on the manifold goes to help with both those situations.
Valterra T58 Twist-On Waste Valve : Amazon.com : Automotive
Old 02-19-2013, 08:02 AM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Maggie
Sage advice! And, don't forget to use the black tank flush when you dump ... either built in or the add on at the outlet.
Old 02-20-2013, 07:30 AM   #8
jornvango's Avatar
Ours doesn't have a built in flush as far as I know. Next to the city water hookup, there's a hookup for the tank flush. I'm not sure if I'm doing something wrong, but when I hookup a hose there and turn on the water + open up the black tank, no water is coming out of the black tank, and after a few seconds the water starts coming out of the hose hookup ... as if the water from the hose isn't going into the system into the black tank.
Could it be clogged up, or am I doing something wrong?
Old 02-20-2013, 07:40 AM   #9
dznf0g's Avatar
Oswego , Illinois
I have heard that they are prone to clogging. Mine is still fine...but it's 12 years newer than yours. Are you saying that water pressure forces a leak at the black tank flush hose connection?
-Rich-
Old 02-20-2013, 08:05 AM   #10
1988 32' Excella
I don't understand, if you have a hookup for the tank flush wouldn't that be the built in flush? (As far as I know that is what everyone else calls it.)
Old 02-20-2013, 08:26 AM   #11
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
When sewer hook-up is available I connect the sewer line and leave both valves closed, and drain only as needed. This prevents any potential back-up of odor from the sewer into the trailer.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 02-20-2013, 09:13 AM   #12
mefly2's Avatar
There is an adapter that connects a water line to the sewer line outlet... below the valve ...that will approximate a tank flush by reverse flow of fresh water back into the black tank.
Old 02-20-2013, 09:55 AM   #13
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I have similar problems with ours (also a '95). Sometimes I can get it to work, but like you said it's usually just spraying water all over the place at the connection. I assume it's at least partially clogged like dznf0g said, possibly because it wasn't used enough.
I have some sensor cleaner that I intend to use in the tanks this spring (said the guy that's been carrying it around since July...). With a little luck maybe it'll help with the flush too.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-02-2013, 08:03 AM   #14
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
In the same delicate thread...I have a new to me 2006 Bambi. Will my Rhino Sewer hose system work on this trailer or does Airstream have a specific sewer hose all models have to use due to the size of diameter of discharge pipe? Thanks in advance. I plan to go ou the first time in a couple of weeks and at moment can't get to the pipe thanks to Mother Natures Snow. sbb
Sbb is offline   Reply With Quote
