Old 04-28-2009, 04:59 PM   #1
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Black/Grey tank roof vent failures
We have had several failures of the tank roof vents where the valves (?) become stuck. Oasis RV replaced several under warranty and at least one that we paid for. Failure to vent either tank can lead to an unpleasant experience when you open the trailer door. Whew. Not enough to set the CO alarm off but... At first I thought I was adding non performing chemicals to the tanks but that wasn't it. The failure typically occurs after we have been using the trailer and then tow down the road a hundred miles or more. I'm thinking it may have to do with our extremely dry south western climate drying out the valve material. Has anyone else experienced this in their 06 vintage trailer (or other)? Anyone have a D.I.Y. fix or preventive measure?
And I did search the forums and didn't find other posts on this topic.
Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 04-28-2009, 05:13 PM   #2
Air2Go's Avatar
Somewhere , Northern New England
Hey, Ken—
I can't vouch for this personally, as I am still in the process of finding an Airstream to call my very own , but based on many online recommendations (and the fact that it was on sale), I purchased The Holding Tank Cyclone, made by Camco. It's designed to pull waste gases out of the trailer using the cyclonic effect; you probably are aware of these gizmos.
But it occurs to me that adding the cyclone to the vent opening would also offer additional protection from the elements for the vent opening itself.
Just a thought. Good luck!
Air2Go is offline   Reply With Quote
Old 04-28-2009, 05:18 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Ken,
Maybe the problem is caused by the lack of water in the P-traps. The water in the trap prevents gases from the tank from backing up into the trailer. You should be able to identify a dry trap with your nose.
Richard
Old 04-28-2009, 07:40 PM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
plumbing vent valves?? what valves??
CO?
not from the waste tank. methane (stinky and explosive) sure. I don't think you'd have a methane detector in your trailer...but hey, they think of everything these days....
dry traps would make it stink inside the trailer. another possibility would be a vent stack pipe that isn't completely attached to the tank. although, you'd smell that all the time, not just immediately after a drive.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-03-2009, 08:32 AM   #5
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Ken
Ken.... What tank roof vent valves are you referring to? Our 2007 25' has round white plastic roof vents that just cover up the plastic ABS vent pipes coming up from the gray & black water tanks as they come through the roof. The only "valves" we have are the ProVent vacuume breaks that are installed on the plastic ABS gray water waste lines adjacent to the shower and the kitchen & bathroom sinks?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Sealing drain pipe to black and grey tank bmklawt Waste Systems, Tanks & Totes 3 04-02-2009 08:05 AM
Combination Grey and Black Tank Idea! A-Merry-Can Waste Systems, Tanks & Totes 8 05-05-2007 08:52 AM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 07:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
CCD Grey/Black Tank Combo LuvSub 2002 - 2005 International 5 05-11-2003 07:04 PM
