Old 05-03-2010, 03:24 PM   #1
2006 16' International CCD
Frisco , Texas
black/grey flush
I have a 2006 16ft bambi. I can't get the black/grey tank flush to work. When I hook up the hose to the flush and turn the water on, it seem like there is some type of blockage. Do I need to keep the water running longer before it opens to my tank or what? Help! thanks
jonm is offline   Reply With Quote
Old 05-03-2010, 03:37 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Hey Jon...Welcome to the forums!
You should be able to hear the water spaying the inside of your holding tank immediately ... without any wait. It sounds like there is some sort of blockage that is not allowing the water in. (You do have the hose hooked up to the flush inlet and not the fresh water fill inlet, right?)
TB & Greg and Abbey Schnauzer
#3954
Old 05-03-2010, 03:42 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Could it be that there is some sort of back flow preventer that is stuck and not alllowing water to pass?
Just a thought ......... Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-07-2010, 05:22 PM   #4
Frisco , Texas
I believe the line to the tank is clogged.
Old 05-07-2010, 06:44 PM   #5
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Since we have owned this trailer, the black tank flush has not worked. I've tried everything possible to fix it. Replaced the back-flow valve, filled the tank up several times with different additives, letting it sit for weeks full with additives, blowing it out with air pressure and adding bags of ice cubes after emptying and then travel to next site. Natta! nothing worked. I've installed one of those wands that has a shut off on it. I was able to cut a hole for the hose inside the refrigerator compartment wall. ran the hose from there to the wand so all I have to do is open the outside ref. door and connect the hose. I then made a bushing to go inside the head to keep the valve open and it also serves to keep the water from splashing back out by the inside hole of the bushing being just big enough for the wand to go in.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Black tank flush uh-oh silversnail 2007 Safari SE 7 07-26-2010 07:48 AM
Black water flush Jenturnr Waste Systems, Tanks & Totes 7 03-23-2010 08:17 PM
Grey Flush wmarsha Waste Systems, Tanks & Totes 5 08-03-2009 07:30 AM
Black tank flush.... drboyd Waste Systems, Tanks & Totes 11 08-01-2003 07:40 AM
Black water flush davidz71 Waste Systems, Tanks & Totes 14 04-28-2002 04:15 PM
