09-23-2015, 05:41 AM
2003 30' Classic
Centerville
, Ohio
Black Flush Extension Hose
Wondering if anyone has ever fiddled with a permanent short extension hose for the black flush.
In addition, anyone ever tried or found a device that you could have on that hose that would successfully connect to a damaged water line, such as we see at all dump stations?
Phil and Kathy Sinewe
2003 30' Classic W/Hensley Arrow
2014 F-150
Centerville, OH
09-23-2015, 08:37 AM
1993 34' Excella
Estancia
, New Mexico
Pretty easy to make one
09-23-2015, 08:47 AM
2008 25' Classic
Full Time
There are rubber hose attachments.
http://www.amazon.com/Camco-22484-Wa.../dp/B000EDOSKG
I don't bother to flush the black tank at dump stations. There are usually others waiting. If I'm at a campsite with water hook ups I'll fill up my black tank to almost full at the site prior to going to the dump station. After dumping add a few gallons of water and a little laundry detergent to slosh around while towing.
I have a 15' garden hose for black tank flushing. If I need to extend it I attach it to my water hose.
Kelvin
09-23-2015, 01:06 PM
2003 30' Classic
Centerville
, Ohio
Amazon.com: Camco 22484 Water Bandit: Automotive
Kelvin
Perfect, that is what I was looking for!! Thanks
2014 F-150
Centerville, OH
09-23-2015, 01:44 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I'm not a fan of the Water Bandit. I had one, it blows off pretty easy even if you try to hold it on. Don't ask me how I know this.
09-24-2015, 10:50 AM
2012 23' FB International
Woodstock
, Ontario
I just fill the Toilet with water and let it drop quickly while the BW valve is still open, to flush the tank if I think it needs it. For the last run of the season I fill the dish tub we keep in the sink with hot soapy water and holding the toilet flush valve open I pour it directly down thru' the flush valve to get a wave of water headed to the open dump valve. My BW tank always seems to be clean when inspected from above through the toilet.
JCW
09-24-2015, 11:42 AM
2013 30' Classic
Greenwood
, Mississippi
My trailer has a short piece of hose from the black tank flush to just outside the hole in the bottom of the water compartment. From there, I use a 10' hose that fits in the water compartment along with channel lock pliers and latex gloves.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-24-2015, 01:43 PM
2016 27' Flying Cloud
Overland Park
, Kansas
[QUOTE=KJRitchie;1687710]There are rubber hose attachments.
I too use one of these. I also carry a hose clamp, if needed, so that it won't easily come off while I'm using it.
09-24-2015, 05:15 PM
2003 31' Classic
Terra Alta
, West Virginia
Mhony
nice idea on the pre-hooked short piece of hose! Brilliant.
Dave
09-24-2015, 07:56 PM
2013 30' Classic
Greenwood
, Mississippi
Not my idea. Came from the factory that way.
TAC #MS-10
Airforums #70955
09-24-2015, 08:46 PM
1995 25' Excella
xxxxx
, xxxxxx
Mine also came with a short hose to go between the black tank flush hook up and the outside water faucet. I have never used it though. I haven't found a need to flush the black tank.
09-25-2015, 04:10 AM
2013 30' Classic
Greenwood
, Mississippi
I don't know if there is actually a "need".
I'm very OCD, though-
I'm afraid my trailer could smell like a public restroom if I don't flush-
TAC #MS-10
Airforums #70955
11-02-2015, 11:31 AM
1Boyscout
2015 28' International
Edmond
, Oklahoma
Black tank flush female fitting on exrterior wall. Used it once and leaked inside kitchen area.....? Anyone else exoerience that?
11-02-2015, 12:09 PM
Sag Harbor
, New York
May have been the vacuum breaker in the black water flush supply line, or other fittings in the area?
See recent comments here:
http://www.airforums.com/forums/f163...ns-143133.html
