Aside from running into any number of situations where "hard plumbing" is just not practical in an RV park or campground (location/availability of the sewer hookup, etc), it would require far more water volume to operate properly than a standard RV toilet and holding tank situation does. Without the water volume for flushing you'd end up with blockages before long. Not pretty. You'd most likely need a household toilet to make it work, and there would still be the possibility of sewage backup, etc. The only time this is really practical is when you're in a "park model" that is intended to be stationery and not move from location to location. Not even sure RV parks would allow it. IMHO you'd be far better off to stick to using holding tanks if you want to move from campground to campground (or RV park to RV park).
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
