Old 10-04-2006, 11:56 AM   #1
1961 Cruiser's Avatar
West Linn , Oregon
Below Floor Holding Tank Options?
Hello Forum. I've just completed lifting the top off of my 1961 Overlander and have cleaned up the frame. I'm now trying to develop a plan for the black, gray, and fresh water tanks. My 61 Overlander originally did not have any holding tanks at all since it was a "trailer park" model. That being the case, I wanted to put all my tanks below the floor if possible. I was planning on installing my fresh tank just ahead of the tandem axle and my gray tank just aft of axles like Uwe did on his 63 Overlander. The part that has me baffled is what to do for the black tank. The original toilet had a 3" drain just outside the street side frame rail since the toilet was located in the aft corner of the trailer. While I'm sure that I could install a 4" deep black tank under floor between the frame rails (aft of the gray tank), I'm not sure how to get 3" lines to it. The frame was notched to get the shower drain to the main dump valve, but I'm not sure there's room to run a couple of 3" lines and the gray tank line through the notched frame opening. I really value all the experience of you forum regulars, so any suggestions or ideas on how I should proceed with the holding tanks would REALLY be appreciated! Thanks - Eric
Name:	61 Airstream Frame.jpg
1961 Cruiser is offline   Reply With Quote
Old 10-04-2006, 12:10 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Attachment 26613
Eric,
You can use an above floor black tank, like I did, and run the plumbing in a similar way.
I kept the original location of toilet, bath and galley. So far I am very pleased with how everything performs.
You can see the black tank and the plumbing layout in my thread. If you have specific questions, or need detail pictures, I have them ready to go in my i-photo file. Feel free to e-mail me, and i will send info as it is available.
Uwe
www.area63productions.com
Old 10-04-2006, 12:13 PM   #3
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Hello Forum. I've just completed lifting the top off of my 1961 Overlander and have cleaned up the frame. Thanks - Eric
Attachment 26613
Now would be a good time to take a very close look at the axles. Yours are the welded on variety, which require a bit of cutting and fabricating to replace. I would tackle that and the preparation/fabrication for the tanks at teh same time, since you will be grinding and welding already.
Uwe
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
