Old 05-25-2015, 06:55 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Belly Pan sag or worse?
We have had this 93 34 footer for about a month or so. Stuck my head between the tires to find the fresh water tank petcock. This is what I saw. Does this look like simple belly pan sag or a problem with the fresh water tank?
ID:	239235   Click image for larger version
Old 05-25-2015, 07:35 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
you are good, its the fresh water tank cover, which looks identical to mine.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-25-2015, 07:40 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mine have been like this since 1991
Old 05-25-2015, 07:45 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
You need to fashion a cover for the access hole where the low point drains (grey pipe) protrude. Without it you'll get lots of road dust up inside. Additionally, the main tank plug and lots of plumbing is exposed to cold freezing air in the winter. It will freeze you plumbing quickly without. Insulate it with 1" styrofoam board. You can see the outline from where it once was.
While your doing work there, replace the white drain pet cock, and tubing to the tank, these are crap and prone to seizing and cracking at the worst of times! Ace hardware has a brass replacement for 6$ with identical centers and specs.
Old 05-25-2015, 09:41 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Tanks a lot
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
crapola. Tail repair worse than I thought eubank Repairing/Replacing Floor &/or Frame 7 03-25-2006 02:41 PM
If you think it is bad, it is probably worse j54mark General Repair Forum 5 09-27-2003 05:54 PM
Rear sag- or no rear sag? aviontt Repairing/Replacing Floor &/or Frame 14 08-27-2003 05:38 PM
Fleas and worse cjholloway The Pet Forum 4 08-09-2003 05:39 PM
