Old 10-31-2012, 08:25 AM   #1
1997 34' Limited
Livingston , Texas
Bad Odor
We have a urine odor in our bathroom that is quite strong. Seems to come and go, though it never quite disappears. Can't seem to find the source. No Leaks anywhere. Recently, Airstream of Spokane, WA installed a new China toilet but can find now fault with there work. Does anyone have an idea of what this source could be.
HPilot is offline   Reply With Quote
Old 10-31-2012, 10:15 AM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Do you always keep an inch of water in the bowl?
If the bowl gasket on the new china toilet won't hold water, or if you don't add water to the bowl after flushing, the odor can be quite strong.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-31-2012, 10:23 AM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Since the folks in Spokane had the toilet off recently, you might call them and ask if they saw any signs of old leakage.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-31-2012, 10:49 AM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
The obvious first choice is the toilet flange gasket. If that's good, maybe I'd check the shower drain. If it's not used often or at all, it might not have enough water in the trap to make an air lock. I'd take a hard look at the sewer vent roof exit point. Some sewer vent stacks are low enough to allow sewer vent air to enter the cabin.
If all else fails, I'd do an objective test for an LP gas leak and a battery gas vent issue.
Old 10-31-2012, 11:20 AM   #5
Check the sewer vent pipe cover gaskets.
They only last 2 to 3 years.
If they are bad, they will allow odors back into the shell.
Old 10-31-2012, 11:42 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The shower drain connects to the grey tank only. Not the black tank so urine odors cannot originate through the shower drain unless there's a much greater issue at work here.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 10-31-2012, 04:21 PM   #7
1993 36' Land Yacht
jackson , Tennessee
Way off the original concept...methinks y'all are eating a lot of asparagus. Of all the veggies, asparagus is notorious for creating foul smelling urine odor. Cut back on the asparagus and hollandaise sauce and the odor will go away.
bukib is offline   Reply With Quote
Old 10-31-2012, 05:22 PM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Andy has it right.
Ahab is offline   Reply With Quote
Old 10-31-2012, 07:41 PM   #9
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
If the toilet is a new china Dometic, ensure that the joint located about half way up is tight. If is not, the negative pressure created by the exhaust fan will draw in some nasty aromas from your black tank. The fix is by removing the toilet, turning it upside down, and tightening the four screws used for holding the thing together. Also ensure that the donut gasket is not wrinkled when you put the thing back on its base.
Jim Flower is offline   Reply With Quote
