Old 09-24-2015, 07:44 AM   #1
2013 25' International
mont st hilaire , Quebec
bad level indication on my monitor
hi
I have a little problem with my tt 2013
when I make a dumping and check my level from my monitor allways the same black empty and gray 1/3 zone
I try to flush a lot but dont work
any suggestion what I can do to fix this little problem
thank you
socool69 is offline   Reply With Quote
Old 09-24-2015, 08:00 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
From you description it sounds like after dumping the black tank registers empty and the gray shows 1/3 full? So the black tank is OK but the grey is not accurate?
Kelvin
Old 09-24-2015, 08:26 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No personal experience with this product but reviews are good. Maker claims use fixes faulty monitor readings.
http://www.amazon.com/gp/product/B00...f_rd_i=desktop
MICHAEL
Old 09-24-2015, 08:51 AM   #4
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Welcome to the club of owners with level guages that don't work. There are a lot of us here.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 09-24-2015, 09:20 AM   #5
KJRitchie's Avatar
2008 25' Classic
Try adding the above to your tank to really flush it out or some dish/laundry soap. Fill the tank partially and then drive around to allow the water to slosh around the tank then dump.
If that doesn't work you may want to try to recalibrate your grey water tank since you have indicated you have flushed it and it is indeed empty.
I purchase this water meter to help me determine how much water I'm putting into the tanks for calibration
http://www.amazon.com/P3-P0550-Water...60_SR160%2C160_
You may want to try to recalibrate your grey water tank.
This is my procedure for calibrating one tank since I can't seem to understand the Micropulse instructions for recalibrating one tank.
1. Verify your tank is indeed empty.
2. Verify your batteries are fully charged. Take the trailer off shore power. My monitor panel doesn't seem to want to calibrate if on shore power and the voltage is 13+ volts.
3. In the water pump area you should find the telephone wires that connect to the tanks. In my 25fb there is a black wire for the black tank, gray for the gray tank and white for the fresh water tank. Each wire is connected to the sensor wire with a telephone line coupler. Unplug the white and black wires. This will isolate those tanks during the Micropulse calibration sequence.
4. Using the Micropulse instructions put the monitor panel into calibration mode and press the Status button until Ready for Empty light is lit.
5. Run your water hose to your kitchen sink and connect the water meter and run 5 gallons of water down the sink. The tank should have enough water to cover the sensor. I usually wait 10 minutes before going to the next step.
6. Press Status button to move to Ready for Full
7. Run the water hose and put in an additional 30 gallons. Your gray tank should be 37 gallons capacity so you should be able to hold 35 gallons. Wait 10 minutes
8. Press the Status button again and finish the calibration. Turn off the monitor panel and then turn it on. It should read full. Turn off the panel
9. Dump the gray water. Turn on the panel and hopefully it will read empty. If you want to test everything then put about 15 gallons and see if the panel reads 1/2 full
10. Don't forget to reconnect your other holding tank sensors after you finish.
Good luck
Kelvin
Old 09-24-2015, 11:42 AM   #6
AWCHIEF's Avatar
Images: 33
I have been experimenting with the "geo" method this summer. One cup each of bleach, liquid dish soap and one cap full of Liquid Calcon added to tanks followed by a couple of gallons of water. No help with the gauge misreading but is doing a good cleaning job and zero nasty smells.
MICHAEL
Old 09-25-2015, 11:17 AM   #7
KYAirstream's Avatar
Northeastern , Kentucky
What made you decide to add liquid dish soap to the mix?
KYAirstream is offline   Reply With Quote
Old 09-26-2015, 06:22 AM   #8
hi and thank you so much for all your ideal
yes Kelvin this is my problem....
I read yesterday and a friend told me exactly what I read
My battry from my TT go under 13 volt and the system was cut so no power
when I restart the system with water on the system take it for zero level
so thank you Kelvin this what I need to do and the dealer told me the same
I love this forum always go think and faster ....
Old 09-26-2015, 06:22 AM   #9
thank you Kelvin I just got the dealer and they told me the same think
Old 09-26-2015, 07:09 AM   #10
AWCHIEF's Avatar
Images: 33
Glad you asked, I misspoke. I have need using Tide liquid detergent.
https://sites.google.com/site/cbruni/
MICHAEL
Old 09-26-2015, 07:23 AM   #11
KJRitchie's Avatar
2008 25' Classic
Calgon is slippery and help keep solids from adhering to the tank surfaces.
Kelvin
Old 09-26-2015, 07:39 AM   #12
Was confused by the mention of dish soap vs detergent. I've been trying the laundry detergent and Calgon as well, with the addition of bleach periodically. Been using this combination since this summer, and so far it's worked pretty well.
Old 09-26-2015, 09:15 AM   #13
AWCHIEF's Avatar
Images: 33
I think plain old liquid dish soap would work just as well in a pinch. The clothing soap seems to have more fragrance.
MICHAEL
Old 09-27-2015, 06:50 AM   #14
the best for me with no smell is BORAX
cheap and really work
clean and no smell
perfect for the tt
Help on removing tank level monitor panel Ditter Waste Systems, Tanks & Totes 1 02-18-2014 11:44 AM
Simple & Inexpensive Battery Level Monitor? John&Vicki Batteries, Univolts, Converters & Inverters 16 11-20-2013 03:46 PM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
Tank level monitor suggestions for new black/gray tank mrsfixit Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
