Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-22-2009, 06:50 AM   #1
The handy accountant
pageclot's Avatar
Profile:  1976 27' Overlander
Scarborough , Ontario
Auxiliary tank dump valve plastic handle replacements
Hi there.
On the eve of a massive 6 day trip, the plastic pull thing on the top of the auxiliary tank dump valve decided to crack in two, and part ways with the steel rod.
Given that I am not inclined towards doing major surgery on the tank valve, and have no parts to do so even if I were so inclined, I'm here to ask for suggestions.
Is there a semi-permanent fix I can make that will give me something to pull up on when I want to dump the aux tank?
Maybe I'll tie some string around the groove.
Or I can always use my pliers, I suppose. And hammer it back down when I'm finished dumping. Yes, that's the ticket. Machinery always responds well when struck with a hammer.
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 07-18-2009, 06:42 PM   #2
454 310! Yea!!!
MaryContrary's Avatar
Profile:  on the road , California
Images: 27
anyone?...i havent tried camping worlds yet, but i'm unsure what SOB valve pully thingies look like
i need a replacement for my black water valve...asap
  • 1984 310 Limited Motorhome
The moon of a bright silver, which dazzles by its shining, illumines a world which surely is no longer ours; for it resembles in nothing what may be seen in other lands.
-pierre loti
MaryContrary is offline   Reply With Quote
Holding Tank Question - Dump Valve tdoescher 1969 Sovereign 1 04-27-2009 11:55 PM
Dump Valve Handle - broke... Craig Waste Systems, Tanks & Totes 4 04-26-2008 08:37 PM
I Broke the Greywater Dump Valve Handle 1Michigander Waste Systems, Tanks & Totes 6 07-06-2007 06:29 PM
Busted the black plastic handle off one of my dump valve gates wacnstac Waste Systems, Tanks & Totes 7 08-07-2006 10:23 AM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 09:21 PM
