Old 07-19-2010, 08:34 AM   #1
jasper2222's Avatar
1996 25' Excella
Tallahassee , Florida
Attaching new flanges to gray and black tanks?
One of my tank flanges (96 excella) cracked and I am in the process of replacing them on both tanks. The flanges are clamped on with a bayonet clamp. Originally if looks like AS also used Vulkem as a double safeguard. With the Vulkem on there, they were a "bear" to get off. Do you think Vulkem is really needed? I would like for the plumbing to be a little more user friendly, but don't want it leaking either. Is tempro any more or less user friendly.
thanks, Richard
jasper2222 is offline   Reply With Quote
Old 07-19-2010, 09:17 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Our 98 Excella also had the white plastic flanges that cracked and started leaking. They where not sealed with Vulkem, but I did use some on the seal, as I couldn't find a replacement, and had to reuse it. The ABS replacement flanges from Out of Doors Mart should not have the same problem as the white plastic flanges from Airstream.
I think the bayonet clamp is all you need as the ABS tank is soft enough will compress against the new flange.
Damon
damonbeals is offline   Reply With Quote
Glass on flanges for black tank Tradestream Waste Systems, Tanks & Totes 2 06-06-2010 09:53 AM
how are the black and gray storage tanks held in place? gmwelder86 1974 - 1979 Sovereign 2 05-26-2010 11:28 AM
Black and Gray water tanks NavyDavesCvl 1965 Caravel 4 03-20-2010 09:21 AM
'59 Tradewind I need new black and gray tanks tomsdayoff 1959-69 Tradewind 28 05-06-2008 10:31 PM
Anyone have any luck putting Gray and black tanks in a 63 tradewind??? durans54 Waste Systems, Tanks & Totes 1 12-05-2006 08:56 PM
